[Minotaur-dev] minotaur daily test results
amahajan
amahajan at iitb.ac.in
Sat Nov 5 12:55:06 CDT 2016
Minotaur daily test report
Sat Nov 5 22:37:01 IST 2016
origin.ieor.iitb.ac.in
Linux origin 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
ls: cannot access build-ampl/bin: No such file or directory
ls: cannot access build-ampl/lib: No such file or directory
ls: cannot access build-ampl/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-debug/bin: No such file or directory
ls: cannot access build-ampl-debug/lib: No such file or directory
ls: cannot access build-ampl-debug/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-static/bin: No such file or directory
ls: cannot access build-ampl-static/lib: No such file or directory
ls: cannot access build-ampl-static/include/minotaur/*: No such file or directory
ls: cannot access build-all/bin: No such file or directory
ls: cannot access build-all/lib: No such file or directory
ls: cannot access build-all/include/minotaur/*: No such file or directory
ls: cannot access build-all-debug/bin: No such file or directory
ls: cannot access build-all-debug/lib: No such file or directory
ls: cannot access build-all-debug/include/minotaur/*: No such file or directory
./daily-lnx-iit-test.sh: line 270: cd: build-all-debug/src/testing: No such file or directory
./daily-lnx-iit-test.sh: line 271: ../../../build-all-debug.out: Permission denied
./daily-lnx-iit-test.sh: line 47: ./scripts/build_with_externals: No such file or directory
./daily-lnx-iit-test.sh: line 50: cd: build-all-static: No such file or directory
ls: cannot access build-all-static/bin: No such file or directory
ls: cannot access build-all-static/lib: No such file or directory
ls: cannot access build-all-static/include/minotaur/*: No such file or directory
rsync: change_dir "/home/amahajan/tmp/minotaur-test/build-all/doxygen/html" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.1]
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libminotaur.a not built.
Errors:
Errors in build-all-debug:
CMake Error at CMakeLists.txt:198 (message):
Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'utest'. Stop.
Errors in build-all:
Errors in build-all-manual:
Makefile:534: minotaur.d: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/ipopt-3.12.3/build/include: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/clp-1.16.6/build/include: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/asl-20150602: No such file or directory
In file included from /home/amahajan/tmp/minotaur-test/src/base/Brancher.h:17:0,
from /home/amahajan/tmp/minotaur-test/src/base/BndProcessor.cpp:15:
/home/amahajan/tmp/minotaur-test/src/base/Types.h:16:32: fatal error: boost/shared_ptr.hpp: No such file or directory
#include <boost/shared_ptr.hpp>
compilation terminated.
make: *** [/home/amahajan/tmp/minotaur-test/src/base/BndProcessor.o] Error 1
Errors in build-all-static:
Errors in build-ampl-debug:
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
Errors in build-base:
--2016-11-05 23:21:54-- http://www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz
Resolving www.mcs.anl.gov (www.mcs.anl.gov)... 140.221.6.95
Connecting to www.mcs.anl.gov (www.mcs.anl.gov)|140.221.6.95|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 11849670 (11M) [application/x-gzip]
Saving to: âminotaur-externals-0.2.tar.gzâ
0K .......... .......... .......... .......... .......... 0% 73.2K 2m37s
50K .......... .......... .......... .......... .......... 0% 219K 1m45s
100K .......... .......... .......... .......... .......... 1% 219K 87s
150K .......... .......... .......... .......... .......... 1% 219K 78s
200K .......... .......... .......... .......... .......... 2% 219K 72s
250K .......... .......... .......... .......... .......... 2% 219K 69s
300K .......... .......... .......... .......... .......... 3% 220K 66s
350K .......... .......... .......... .......... .......... 3% 46.4M 57s
400K .......... .......... .......... .......... .......... 3% 220K 56s
450K .......... .......... .......... .......... .......... 4% 220K 56s
500K .......... .......... .......... .......... .......... 4% 62.9M 50s
550K .......... .......... .......... .......... .......... 5% 220K 50s
600K .......... .......... .......... .......... .......... 5% 58.3M 46s
650K .......... .......... .......... .......... .......... 6% 220K 46s
700K .......... .......... .......... .......... .......... 6% 62.7M 43s
750K .......... .......... .......... .......... .......... 6% 220K 43s
800K .......... .......... .......... .......... .......... 7% 54.7M 40s
850K .......... .......... .......... .......... .......... 7% 78.4M 38s
900K .......... .......... .......... .......... .......... 8% 220K 38s
950K .......... .......... .......... .......... .......... 8% 89.1M 36s
1000K .......... .......... .......... .......... .......... 9% 66.7M 34s
1050K .......... .......... .......... .......... .......... 9% 220K 35s
1100K .......... .......... .......... .......... .......... 9% 87.9M 33s
1150K .......... .......... .......... .......... .......... 10% 95.8M 32s
1200K .......... .......... .......... .......... .......... 10% 220K 32s
1250K .......... .......... .......... .......... .......... 11% 91.1M 31s
1300K .......... .......... .......... .......... .......... 11% 122M 29s
1350K .......... .......... .......... .......... .......... 12% 220K 30s
1400K .......... .......... .......... .......... .......... 12% 98.3M 29s
1450K .......... .......... .......... .......... .......... 12% 101M 28s
1500K .......... .......... .......... .......... .......... 13% 221K 28s
1550K .......... .......... .......... .......... .......... 13% 75.0M 27s
1600K .......... .......... .......... .......... .......... 14% 86.7M 26s
1650K .......... .......... .......... .......... .......... 14% 110M 25s
1700K .......... .......... .......... .......... .......... 15% 221K 26s
1750K .......... .......... .......... .......... .......... 15% 76.8M 25s
1800K .......... .......... .......... .......... .......... 15% 79.9M 24s
1850K .......... .......... .......... .......... .......... 16% 106M 23s
1900K .......... .......... .......... .......... .......... 16% 121M 23s
1950K .......... .......... .......... .......... .......... 17% 221K 23s
2000K .......... .......... .......... .......... .......... 17% 87.2M 22s
2050K .......... .......... .......... .......... .......... 18% 146M 22s
2100K .......... .......... .......... .......... .......... 18% 97.3M 21s
2150K .......... .......... .......... .......... .......... 19% 106M 20s
2200K .......... .......... .......... .......... .......... 19% 222K 21s
2250K .......... .......... .......... .......... .......... 19% 37.9M 20s
2300K .......... .......... .......... .......... .......... 20% 113M 20s
2350K .......... .......... .......... .......... .......... 20% 119M 19s
2400K .......... .......... .......... .......... .......... 21% 97.7M 19s
2450K .......... .......... .......... .......... .......... 21% 120M 18s
2500K .......... .......... .......... .......... .......... 22% 222K 19s
2550K .......... .......... .......... .......... .......... 22% 47.2M 18s
2600K .......... .......... .......... .......... .......... 22% 52.4M 18s
2650K .......... .......... .......... .......... .......... 23% 143M 17s
2700K .......... .......... .......... .......... .......... 23% 122M 17s
2750K .......... .......... .......... .......... .......... 24% 90.8M 16s
2800K .......... .......... .......... .......... .......... 24% 103M 16s
2850K .......... .......... .......... .......... .......... 25% 145M 16s
2900K .......... .......... .......... .......... .......... 25% 222K 16s
2950K .......... .......... .......... .......... .......... 25% 71.8M 16s
3000K .......... .......... .......... .......... .......... 26% 77.7M 15s
3050K .......... .......... .......... .......... .......... 26% 111M 15s
3100K .......... .......... .......... .......... .......... 27% 111M 15s
3150K .......... .......... .......... .......... .......... 27% 126M 14s
3200K .......... .......... .......... .......... .......... 28% 107M 14s
3250K .......... .......... .......... .......... .......... 28% 108M 14s
3300K .......... .......... .......... .......... .......... 28% 223K 14s
3350K .......... .......... .......... .......... .......... 29% 87.6M 14s
3400K .......... .......... .......... .......... .......... 29% 68.4M 13s
3450K .......... .......... .......... .......... .......... 30% 101M 13s
3500K .......... .......... .......... .......... .......... 30% 105M 13s
3550K .......... .......... .......... .......... .......... 31% 123M 13s
3600K .......... .......... .......... .......... .......... 31% 110M 12s
3650K .......... .......... .......... .......... .......... 31% 106M 12s
3700K .......... .......... .......... .......... .......... 32% 224K 12s
3750K .......... .......... .......... .......... .......... 32% 38.3M 12s
3800K .......... .......... .......... .......... .......... 33% 85.3M 12s
3850K .......... .......... .......... .......... .......... 33% 103M 12s
3900K .......... .......... .......... .......... .......... 34% 89.7M 11s
3950K .......... .......... .......... .......... .......... 34% 110M 11s
4000K .......... .......... .......... .......... .......... 34% 109M 11s
4050K .......... .......... .......... .......... .......... 35% 98.9M 11s
4100K .......... .......... .......... .......... .......... 35% 137M 11s
4150K .......... .......... .......... .......... .......... 36% 224K 11s
4200K .......... .......... .......... .......... .......... 36% 55.0M 11s
4250K .......... .......... .......... .......... .......... 37% 67.2M 10s
4300K .......... .......... .......... .......... .......... 37% 98.4M 10s
4350K .......... .......... .......... .......... .......... 38% 90.7M 10s
4400K .......... .......... .......... .......... .......... 38% 107M 10s
4450K .......... .......... .......... .......... .......... 38% 135M 10s
4500K .......... .......... .......... .......... .......... 39% 98.9M 10s
4550K .......... .......... .......... .......... .......... 39% 104M 9s
4600K .......... .......... .......... .......... .......... 40% 131M 9s
4650K .......... .......... .......... .......... .......... 40% 224K 9s
4700K .......... .......... .......... .......... .......... 41% 43.9M 9s
4750K .......... .......... .......... .......... .......... 41% 95.4M 9s
4800K .......... .......... .......... .......... .......... 41% 150M 9s
4850K .......... .......... .......... .......... .......... 42% 92.7M 9s
4900K .......... .......... .......... .......... .......... 42% 124M 9s
4950K .......... .......... .......... .......... .......... 43% 100M 8s
5000K .......... .......... .......... .......... .......... 43% 150M 8s
5050K .......... .......... .......... .......... .......... 44% 120M 8s
5100K .......... .......... .......... .......... .......... 44% 100M 8s
5150K .......... .......... .......... .......... .......... 44% 91.4M 8s
5200K .......... .......... .......... .......... .......... 45% 224K 8s
5250K .......... .......... .......... .......... .......... 45% 79.4M 8s
5300K .......... .......... .......... .......... .......... 46% 73.4M 8s
5350K .......... .......... .......... .......... .......... 46% 115M 8s
5400K .......... .......... .......... .......... .......... 47% 99.9M 7s
5450K .......... .......... .......... .......... .......... 47% 120M 7s
5500K .......... .......... .......... .......... .......... 47% 104M 7s
5550K .......... .......... .......... .......... .......... 48% 114M 7s
5600K .......... .......... .......... .......... .......... 48% 106M 7s
5650K .......... .......... .......... .......... .......... 49% 109M 7s
5700K .......... .......... .......... .......... .......... 49% 119M 7s
5750K .......... .......... .......... .......... .......... 50% 1.31M 7s
5800K .......... .......... .......... .......... .......... 50% 269K 7s
5850K .......... .......... .......... .......... .......... 50% 65.5M 7s
5900K .......... .......... .......... .......... .......... 51% 114M 6s
5950K .......... .......... .......... .......... .......... 51% 114M 6s
6000K .......... .......... .......... .......... .......... 52% 119M 6s
6050K .......... .......... .......... .......... .......... 52% 100M 6s
6100K .......... .......... .......... .......... .......... 53% 119M 6s
6150K .......... .......... .......... .......... .......... 53% 118M 6s
6200K .......... .......... .......... .......... .......... 54% 115M 6s
6250K .......... .......... .......... .......... .......... 54% 97.1M 6s
6300K .......... .......... .......... .......... .......... 54% 119M 6s
6350K .......... .......... .......... .......... .......... 55% 120M 6s
6400K .......... .......... .......... .......... .......... 55% 121M 5s
6450K .......... .......... .......... .......... .......... 56% 67.0M 5s
6500K .......... .......... .......... .......... .......... 56% 226K 5s
6550K .......... .......... .......... .......... .......... 57% 97.2M 5s
6600K .......... .......... .......... .......... .......... 57% 84.5M 5s
6650K .......... .......... .......... .......... .......... 57% 98.5M 5s
6700K .......... .......... .......... .......... .......... 58% 117M 5s
6750K .......... .......... .......... .......... .......... 58% 102M 5s
6800K .......... .......... .......... .......... .......... 59% 117M 5s
6850K .......... .......... .......... .......... .......... 59% 116M 5s
6900K .......... .......... .......... .......... .......... 60% 104M 5s
6950K .......... .......... .......... .......... .......... 60% 113M 5s
7000K .......... .......... .......... .......... .......... 60% 116M 5s
7050K .......... .......... .......... .......... .......... 61% 111M 4s
7100K .......... .......... .......... .......... .......... 61% 100M 4s
7150K .......... .......... .......... .......... .......... 62% 118M 4s
7200K .......... .......... .......... .......... .......... 62% 118M 4s
7250K .......... .......... .......... .......... .......... 63% 114M 4s
7300K .......... .......... .......... .......... .......... 63% 103M 4s
7350K .......... .......... .......... .......... .......... 63% 118M 4s
7400K .......... .......... .......... .......... .......... 64% 227K 4s
7450K .......... .......... .......... .......... .......... 64% 122M 4s
7500K .......... .......... .......... .......... .......... 65% 67.4M 4s
7550K .......... .......... .......... .......... .......... 65% 112M 4s
7600K .......... .......... .......... .......... .......... 66% 118M 4s
7650K .......... .......... .......... .......... .......... 66% 99.8M 4s
7700K .......... .......... .......... .......... .......... 66% 114M 4s
7750K .......... .......... .......... .......... .......... 67% 116M 4s
7800K .......... .......... .......... .......... .......... 67% 119M 3s
7850K .......... .......... .......... .......... .......... 68% 100M 3s
7900K .......... .......... .......... .......... .......... 68% 113M 3s
7950K .......... .......... .......... .......... .......... 69% 114M 3s
8000K .......... .......... .......... .......... .......... 69% 114M 3s
8050K .......... .......... .......... .......... .......... 69% 104M 3s
8100K .......... .......... .......... .......... .......... 70% 116M 3s
8150K .......... .......... .......... .......... .......... 70% 115M 3s
8200K .......... .......... .......... .......... .......... 71% 111M 3s
8250K .......... .......... .......... .......... .......... 71% 103M 3s
8300K .......... .......... .......... .......... .......... 72% 114M 3s
8350K .......... .......... .......... .......... .......... 72% 120M 3s
8400K .......... .......... .......... .......... .......... 73% 108M 3s
8450K .......... .......... .......... .......... .......... 73% 101M 3s
8500K .......... .......... .......... .......... .......... 73% 1.48M 3s
8550K .......... .......... .......... .......... .......... 74% 269K 3s
8600K .......... .......... .......... .......... .......... 74% 111M 3s
8650K .......... .......... .......... .......... .......... 75% 108M 2s
8700K .......... .......... .......... .......... .......... 75% 118M 2s
8750K .......... .......... .......... .......... .......... 76% 104M 2s
8800K .......... .......... .......... .......... .......... 76% 116M 2s
8850K .......... .......... .......... .......... .......... 76% 121M 2s
8900K .......... .......... .......... .......... .......... 77% 119M 2s
8950K .......... .......... .......... .......... .......... 77% 105M 2s
9000K .......... .......... .......... .......... .......... 78% 117M 2s
9050K .......... .......... .......... .......... .......... 78% 120M 2s
9100K .......... .......... .......... .......... .......... 79% 118M 2s
9150K .......... .......... .......... .......... .......... 79% 105M 2s
9200K .......... .......... .......... .......... .......... 79% 118M 2s
9250K .......... .......... .......... .......... .......... 80% 107M 2s
9300K .......... .......... .......... .......... .......... 80% 109M 2s
9350K .......... .......... .......... .......... .......... 81% 127M 2s
9400K .......... .......... .......... .......... .......... 81% 108M 2s
9450K .......... .......... .......... .......... .......... 82% 108M 2s
9500K .......... .......... .......... .......... .......... 82% 112M 2s
9550K .......... .......... .......... .......... .......... 82% 114M 2s
9600K .......... .......... .......... .......... .......... 83% 120M 2s
9650K .......... .......... .......... .......... .......... 83% 101M 1s
9700K .......... .......... .......... .......... .......... 84% 118M 1s
9750K .......... .......... .......... .......... .......... 84% 111M 1s
9800K .......... .......... .......... .......... .......... 85% 109M 1s
9850K .......... .......... .......... .......... .......... 85% 124M 1s
9900K .......... .......... .......... .......... .......... 85% 107M 1s
9950K .......... .......... .......... .......... .......... 86% 1.56M 1s
10000K .......... .......... .......... .......... .......... 86% 270K 1s
10050K .......... .......... .......... .......... .......... 87% 102M 1s
10100K .......... .......... .......... .......... .......... 87% 109M 1s
10150K .......... .......... .......... .......... .......... 88% 134M 1s
10200K .......... .......... .......... .......... .......... 88% 110M 1s
10250K .......... .......... .......... .......... .......... 89% 109M 1s
10300K .......... .......... .......... .......... .......... 89% 119M 1s
10350K .......... .......... .......... .......... .......... 89% 112M 1s
10400K .......... .......... .......... .......... .......... 90% 107M 1s
10450K .......... .......... .......... .......... .......... 90% 109M 1s
10500K .......... .......... .......... .......... .......... 91% 117M 1s
10550K .......... .......... .......... .......... .......... 91% 112M 1s
10600K .......... .......... .......... .......... .......... 92% 108M 1s
10650K .......... .......... .......... .......... .......... 92% 124M 1s
10700K .......... .......... .......... .......... .......... 92% 110M 1s
10750K .......... .......... .......... .......... .......... 93% 107M 1s
10800K .......... .......... .......... .......... .......... 93% 109M 1s
10850K .......... .......... .......... .......... .......... 94% 120M 0s
10900K .......... .......... .......... .......... .......... 94% 110M 0s
10950K .......... .......... .......... .......... .......... 95% 107M 0s
11000K .......... .......... .......... .......... .......... 95% 118M 0s
11050K .......... .......... .......... .......... .......... 95% 112M 0s
11100K .......... .......... .......... .......... .......... 96% 108M 0s
11150K .......... .......... .......... .......... .......... 96% 123M 0s
11200K .......... .......... .......... .......... .......... 97% 108M 0s
11250K .......... .......... .......... .......... .......... 97% 109M 0s
11300K .......... .......... .......... .......... .......... 98% 121M 0s
11350K .......... .......... .......... .......... .......... 98% 107M 0s
11400K .......... .......... .......... .......... .......... 98% 109M 0s
11450K .......... .......... .......... .......... .......... 99% 120M 0s
11500K .......... .......... .......... .......... .......... 99% 109M 0s
11550K .......... .......... . 100% 109M=7.8s
2016-11-05 23:22:03 (1.45 MB/s) - âminotaur-externals-0.2.tar.gzâ saved [11849670/11849670]
configure: WARNING: No solver available, examples will not work.
../../../CoinUtils/src/CoinFactorization2.cpp: In member function 'int CoinFactorization::factorDense()':
../../../CoinUtils/src/CoinFactorization2.cpp:520:11: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += (numberDense_+1)/(sizeof(CoinFactorizationDouble)/sizeof(int));
../../../CoinUtils/src/CoinFactorization2.cpp:521:11: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += 2*((numberDense_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinFactorization2.cpp:522:11: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += ((numberRows_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinLpIO.cpp: In member function 'void CoinLpIO::readLp(FILE*)':
../../../CoinUtils/src/CoinLpIO.cpp:2264:29: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
int length=strlen(buff);
../../../CoinUtils/src/CoinLpIO.cpp:2316:31: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
int length=strlen(next+1);
../../../CoinUtils/src/CoinStructuredModel.cpp: In member function 'int CoinStructuredModel::decompose(const CoinPackedMatrix&, const double*, const double*, const double*, const double*, const double*, int, int, int*, double)':
../../../CoinUtils/src/CoinStructuredModel.cpp:761:10: warning: variable 'goodDW' set but not used [-Wunused-but-set-variable]
bool goodDW=true;
../../../CoinUtils/src/CoinStructuredModel.cpp:1343:10: warning: variable 'goodBenders' set but not used [-Wunused-but-set-variable]
bool goodBenders=true;
../../../CoinUtils/src/CoinPresolveDual.cpp: In static member function 'static const CoinPresolveAction* remove_dual_action::presolve(CoinPresolveMatrix*, const CoinPresolveAction*)':
../../../CoinUtils/src/CoinPresolveDual.cpp:236:20: warning: unused variable 'lb' [-Wunused-variable]
const double lb = clo[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:237:20: warning: unused variable 'ub' [-Wunused-variable]
const double ub = cup[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:642:13: warning: unused variable 'no_clb' [-Wunused-variable]
const bool no_clb = (active[j]&5)==0 ;
../../../CoinUtils/src/CoinRational.cpp: In member function 'bool CoinRational::nearestRational_(double, double, long int)':
../../../CoinUtils/src/CoinRational.cpp:30:46: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
double mediant = (a + c)/(double(b + d));
../../../CoinUtils/src/CoinRational.cpp:60:30: warning: conversion to 'long int' from 'double' may alter its value [-Wfloat-conversion]
numerator_ += labs(intpart) * denominator_;
../../../CoinUtils/src/CoinRational.cpp:64:52: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
return fabs(val - numerator_/double(denominator_)) <= maxdelta;
../../../../Osi/src/Osi/OsiSolverInterface.cpp: In member function 'int OsiSolverInterface::differentModel(OsiSolverInterface&, bool)':
../../../../Osi/src/Osi/OsiSolverInterface.cpp:1880:8: warning: unused variable 'gotHint' [-Wunused-variable]
bool gotHint = (getHintParam(OsiDoReducePrint,takeHint,strength));
libtool: install: warning: relinking `libOsi.la'
libtool: install: warning: relinking `libOsiCommonTests.la'
../../../Clp/src/ClpPlusMinusOneMatrix.cpp:459:13: warning: 'doPlusOnes' defined but not used [-Wunused-variable]
static bool doPlusOnes=true;
../../../Clp/src/ClpSimplex.cpp: In member function 'int ClpSimplex::fathom(void*)':
../../../Clp/src/ClpSimplex.cpp:11081:15: warning: unused variable 'statusWeights' [-Wunused-variable]
int statusWeights = fastDual2(info);
../../../Clp/src/ClpSimplexOther.cpp: In member function 'int ClpSimplexOther::setInDual(ClpSimplex*)':
../../../Clp/src/ClpSimplexOther.cpp:1313:12: warning: unused variable 'statusD' [-Wunused-variable]
Status statusD = dualProblem->getRowStatus(iColumn);
../../../Clp/src/ClpSimplexOther.cpp:1314:12: warning: unused variable 'statusDJ' [-Wunused-variable]
Status statusDJ = dualProblem->getColumnStatus(jColumn);
../../../Clp/src/ClpSimplexOther.cpp:1352:12: warning: unused variable 'statusD' [-Wunused-variable]
Status statusD = dualProblem->getColumnStatus(iRow);
../../../Clp/src/ClpSolver.cpp: In function 'void statistics(ClpSimplex*, ClpSimplex*)':
../../../Clp/src/ClpSolver.cpp:3756:10: warning: variable 'numberWritten' set but not used [-Wunused-but-set-variable]
size_t numberWritten;
libtool: install: warning: relinking `libClp.la'
libtool: install: warning: relinking `libClpSolver.la'
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::initialSolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:148:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::resolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:843:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
bool gotHint = (getHintParam(OsiDoInBranchAndCut,takeHint,strength));
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'int OsiClpSolverInterface::infeasibleOtherWay(char*)':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9967:22: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
whichWay[iColumn] *=2;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9972:22: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9822:7: warning: unused variable 'iRow' [-Wunused-variable]
int iRow,iColumn;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9840:17: warning: unused variable 'objective' [-Wunused-variable]
const double *objective = getObjCoefficients() ;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9841:10: warning: unused variable 'direction' [-Wunused-variable]
double direction = getObjSense();
libtool: install: warning: relinking `libOsiClp.la'
ar: creating libbqpd.a
filteraux.f:105.24:
. 0.D0,.false.)
1
Warning: Rank mismatch in argument 'w' at (1) (rank-1 and scalar)
ar: creating libfiltersqp.a
ar: creating amplsolver.a
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 189: cd: minotaur-externals//build: No such file or directory
make: *** No rule to make target 'distclean'. Stop.
: logger ok! OK (39)
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Sat Nov 5 23:25:06 IST 2016
More information about the Minotaur-dev
