[Minotaur-dev] minotaur daily test results
amahajan
amahajan at iitb.ac.in
Fri Nov 4 12:56:56 CDT 2016
Minotaur daily test report
Fri Nov 4 22:37:02 IST 2016
origin.ieor.iitb.ac.in
Linux origin 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
ls: cannot access build-ampl/bin: No such file or directory
ls: cannot access build-ampl/lib: No such file or directory
ls: cannot access build-ampl/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-debug/bin: No such file or directory
ls: cannot access build-ampl-debug/lib: No such file or directory
ls: cannot access build-ampl-debug/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-static/bin: No such file or directory
ls: cannot access build-ampl-static/lib: No such file or directory
ls: cannot access build-ampl-static/include/minotaur/*: No such file or directory
ls: cannot access build-all/bin: No such file or directory
ls: cannot access build-all/lib: No such file or directory
ls: cannot access build-all/include/minotaur/*: No such file or directory
ls: cannot access build-all-debug/bin: No such file or directory
ls: cannot access build-all-debug/lib: No such file or directory
ls: cannot access build-all-debug/include/minotaur/*: No such file or directory
./daily-lnx-iit-test.sh: line 270: cd: build-all-debug/src/testing: No such file or directory
./daily-lnx-iit-test.sh: line 271: ../../../build-all-debug.out: Permission denied
./daily-lnx-iit-test.sh: line 47: ./scripts/build_with_externals: No such file or directory
./daily-lnx-iit-test.sh: line 50: cd: build-all-static: No such file or directory
ls: cannot access build-all-static/bin: No such file or directory
ls: cannot access build-all-static/lib: No such file or directory
ls: cannot access build-all-static/include/minotaur/*: No such file or directory
ssh: connect to host 10.105.27.98 port 22: Connection timed out
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(226) [sender=3.1.1]
Summary
compiling build-base: ERROR. lib/libminotaur.so not built.
make utest output for build-base: ERROR
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libminotaur.a not built.
Errors:
Errors in build-all-debug:
CMake Error at CMakeLists.txt:198 (message):
Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'utest'. Stop.
Errors in build-all:
Errors in build-all-manual:
Makefile:534: minotaur.d: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/ipopt-3.12.3/build/include: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/clp-1.16.6/build/include: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/asl-20150602: No such file or directory
In file included from /home/amahajan/tmp/minotaur-test/src/base/Brancher.h:17:0,
from /home/amahajan/tmp/minotaur-test/src/base/BndProcessor.cpp:15:
/home/amahajan/tmp/minotaur-test/src/base/Types.h:16:32: fatal error: boost/shared_ptr.hpp: No such file or directory
#include <boost/shared_ptr.hpp>
compilation terminated.
make: *** [/home/amahajan/tmp/minotaur-test/src/base/BndProcessor.o] Error 1
Errors in build-all-static:
Errors in build-ampl-debug:
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
Errors in build-base:
--2016-11-04 23:21:57-- http://www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz
Resolving www.mcs.anl.gov (www.mcs.anl.gov)... 140.221.6.95
Connecting to www.mcs.anl.gov (www.mcs.anl.gov)|140.221.6.95|:80... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
Location: https://internet.iitb.ac.in/index.php?redirecthost=www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz& [following]
--2016-11-04 23:21:58-- https://internet.iitb.ac.in/index.php?redirecthost=www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz&
Resolving internet.iitb.ac.in (internet.iitb.ac.in)... 10.201.250.201
Connecting to internet.iitb.ac.in (internet.iitb.ac.in)|10.201.250.201|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: âminotaur-externals-0.2.tar.gzâ
0K .......... ... 150M=0s
Last-modified header missing -- time-stamps turned off.
2016-11-04 23:21:58 (150 MB/s) - âminotaur-externals-0.2.tar.gzâ saved [14208]
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 122: cd: minotaur-externals/clp-1.16.6: No such file or directory
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 125: ../configure: No such file or directory
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 143: cd: minotaur-externals/bqpd-3: No such file or directory
make: *** No targets specified and no makefile found. Stop.
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 153: cd: minotaur-externals/filter-102/src: No such file or directory
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 163: cd: minotaur-externals/asl-20150602: No such file or directory
chmod: cannot access âconfigurehereâ: No such file or directory
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 165: ./configurehere: No such file or directory
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 170: cd: minotaur-externals/cppunit-1.13.2: No such file or directory
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 177: ../../configure: No such file or directory
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 184: cd: minotaur-externals/clp-1.16.6/build: No such file or directory
make: *** No rule to make target 'distclean'. Stop.
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 189: cd: minotaur-externals//build: No such file or directory
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 194: cd: minotaur-externals/bqpd-3: No such file or directory
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 199: cd: minotaur-externals/filter-102: No such file or directory
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 204: cd: minotaur-externals/cppunit-1.13.2/build/tmp: No such file or directory
Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Fri Nov 4 23:26:56 IST 2016
More information about the Minotaur-dev
