[Minotaur-dev] minotaur daily test results
amahajan
amahajan at iitb.ac.in
Thu Nov 3 12:55:04 CDT 2016
Minotaur daily test report
Thu Nov 3 22:37:02 IST 2016
origin.ieor.iitb.ac.in
Linux origin 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u1 (2016-09-03) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
ls: cannot access build-ampl/bin: No such file or directory
ls: cannot access build-ampl/lib: No such file or directory
ls: cannot access build-ampl/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-debug/bin: No such file or directory
ls: cannot access build-ampl-debug/lib: No such file or directory
ls: cannot access build-ampl-debug/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-static/bin: No such file or directory
ls: cannot access build-ampl-static/lib: No such file or directory
ls: cannot access build-ampl-static/include/minotaur/*: No such file or directory
ls: cannot access build-all/bin: No such file or directory
ls: cannot access build-all/lib: No such file or directory
ls: cannot access build-all/include/minotaur/*: No such file or directory
ls: cannot access build-all-debug/bin: No such file or directory
ls: cannot access build-all-debug/lib: No such file or directory
ls: cannot access build-all-debug/include/minotaur/*: No such file or directory
./daily-lnx-iit-test.sh: line 270: cd: build-all-debug/src/testing: No such file or directory
./daily-lnx-iit-test.sh: line 271: ../../../build-all-debug.out: Permission denied
./daily-lnx-iit-test.sh: line 47: ./scripts/build_with_externals: No such file or directory
./daily-lnx-iit-test.sh: line 50: cd: build-all-static: No such file or directory
ls: cannot access build-all-static/bin: No such file or directory
ls: cannot access build-all-static/lib: No such file or directory
ls: cannot access build-all-static/include/minotaur/*: No such file or directory
ssh: connect to host 10.105.27.98 port 22: No route to host
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(226) [sender=3.1.1]
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-base-debug: ERROR
compiling build-base-static: ERROR. lib/libminotaur.a not built.
make utest output for build-base-static: ERROR
compiling build-filter: ERROR. lib/libminotaur.so not built.
make utest output for build-filter: ERROR
compiling build-filter-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: ERROR. lib/libminotaur.a not built.
make utest output for build-filter-static: ERROR
compiling build-ipopt: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ipopt-static: ERROR
compiling build-osi: ERROR. lib/libminotaur.so not built.
make utest output for build-osi: ERROR
compiling build-osi-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: ERROR. lib/libminotaur.a not built.
make utest output for build-osi-static: ERROR
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: ERROR
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: ERROR
compiling build-all-manual: ERROR. lib/libminotaur.a not built.
Errors:
Errors in build-all-debug:
CMake Error at CMakeLists.txt:198 (message):
Minotaur config: /home/amahajan/tmp/minotaur-test/minotaur-externals/boost/shared_ptr.hpp not found in BOOST_INC_DIR_F
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'utest'. Stop.
Errors in build-all:
Errors in build-all-manual:
Makefile:534: minotaur.d: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/ipopt-3.12.3/build/include: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/clp-1.16.6/build/include: No such file or directory
cc1plus: warning: /home/amahajan/tmp/minotaur-test/minotaur-externals/asl-20150602: No such file or directory
In file included from /home/amahajan/tmp/minotaur-test/src/base/Brancher.h:17:0,
from /home/amahajan/tmp/minotaur-test/src/base/BndProcessor.cpp:15:
/home/amahajan/tmp/minotaur-test/src/base/Types.h:16:32: fatal error: boost/shared_ptr.hpp: No such file or directory
#include <boost/shared_ptr.hpp>
compilation terminated.
make: *** [/home/amahajan/tmp/minotaur-test/src/base/BndProcessor.o] Error 1
Errors in build-all-static:
Errors in build-ampl-debug:
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
Errors in build-base:
--2016-11-03 23:21:56-- http://www.mcs.anl.gov/~mahajan/minotaur/restricted/minotaur-externals-0.2.tar.gz
Resolving www.mcs.anl.gov (www.mcs.anl.gov)... 140.221.6.95
Connecting to www.mcs.anl.gov (www.mcs.anl.gov)|140.221.6.95|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 11849670 (11M) [application/x-gzip]
Saving to: âminotaur-externals-0.2.tar.gzâ
0K .......... .......... .......... .......... .......... 0% 73.2K 2m37s
50K .......... .......... .......... .......... .......... 0% 219K 1m45s
100K .......... .......... .......... .......... .......... 1% 218K 87s
150K .......... .......... .......... .......... .......... 1% 219K 78s
200K .......... .......... .......... .......... .......... 2% 220K 72s
250K .......... .......... .......... .......... .......... 2% 220K 68s
300K .......... .......... .......... .......... .......... 3% 59.4M 58s
350K .......... .......... .......... .......... .......... 3% 220K 57s
400K .......... .......... .......... .......... .......... 3% 31.6M 51s
450K .......... .......... .......... .......... .......... 4% 221K 50s
500K .......... .......... .......... .......... .......... 4% 29.0M 46s
550K .......... .......... .......... .......... .......... 5% 221K 46s
600K .......... .......... .......... .......... .......... 5% 92.6M 42s
650K .......... .......... .......... .......... .......... 6% 220K 42s
700K .......... .......... .......... .......... .......... 6% 83.8M 39s
750K .......... .......... .......... .......... .......... 6% 34.9M 37s
800K .......... .......... .......... .......... .......... 7% 221K 37s
850K .......... .......... .......... .......... .......... 7% 91.5M 35s
900K .......... .......... .......... .......... .......... 8% 30.3M 33s
950K .......... .......... .......... .......... .......... 8% 221K 34s
1000K .......... .......... .......... .......... .......... 9% 61.2M 32s
1050K .......... .......... .......... .......... .......... 9% 59.7M 30s
1100K .......... .......... .......... .......... .......... 9% 221K 31s
1150K .......... .......... .......... .......... .......... 10% 66.9M 30s
1200K .......... .......... .......... .......... .......... 10% 70.9M 28s
1250K .......... .......... .......... .......... .......... 11% 49.2M 27s
1300K .......... .......... .......... .......... .......... 11% 222K 28s
1350K .......... .......... .......... .......... .......... 12% 71.2M 27s
1400K .......... .......... .......... .......... .......... 12% 106M 25s
1450K .......... .......... .......... .......... .......... 12% 67.7M 25s
1500K .......... .......... .......... .......... .......... 13% 222K 25s
1550K .......... .......... .......... .......... .......... 13% 111M 24s
1600K .......... .......... .......... .......... .......... 14% 53.8M 23s
1650K .......... .......... .......... .......... .......... 14% 121M 23s
1700K .......... .......... .......... .......... .......... 15% 131M 22s
1750K .......... .......... .......... .......... .......... 15% 77.7M 21s
1800K .......... .......... .......... .......... .......... 15% 222K 22s
1850K .......... .......... .......... .......... .......... 16% 74.0M 21s
1900K .......... .......... .......... .......... .......... 16% 82.2M 20s
1950K .......... .......... .......... .......... .......... 17% 108M 20s
2000K .......... .......... .......... .......... .......... 17% 121M 19s
2050K .......... .......... .......... .......... .......... 18% 94.8M 19s
2100K .......... .......... .......... .......... .......... 18% 222K 19s
2150K .......... .......... .......... .......... .......... 19% 74.8M 18s
2200K .......... .......... .......... .......... .......... 19% 73.0M 18s
2250K .......... .......... .......... .......... .......... 19% 96.9M 17s
2300K .......... .......... .......... .......... .......... 20% 128M 17s
2350K .......... .......... .......... .......... .......... 20% 98.4M 17s
2400K .......... .......... .......... .......... .......... 21% 128M 16s
2450K .......... .......... .......... .......... .......... 21% 222K 17s
2500K .......... .......... .......... .......... .......... 22% 62.8M 16s
2550K .......... .......... .......... .......... .......... 22% 89.2M 16s
2600K .......... .......... .......... .......... .......... 22% 109M 15s
2650K .......... .......... .......... .......... .......... 23% 109M 15s
2700K .......... .......... .......... .......... .......... 23% 145M 15s
2750K .......... .......... .......... .......... .......... 24% 100M 14s
2800K .......... .......... .......... .......... .......... 24% 69.9M 14s
2850K .......... .......... .......... .......... .......... 25% 222K 14s
2900K .......... .......... .......... .......... .......... 25% 86.3M 14s
2950K .......... .......... .......... .......... .......... 25% 110M 14s
3000K .......... .......... .......... .......... .......... 26% 94.7M 13s
3050K .......... .......... .......... .......... .......... 26% 99.1M 13s
3100K .......... .......... .......... .......... .......... 27% 134M 13s
3150K .......... .......... .......... .......... .......... 27% 117M 13s
3200K .......... .......... .......... .......... .......... 28% 103M 12s
3250K .......... .......... .......... .......... .......... 28% 223K 13s
3300K .......... .......... .......... .......... .......... 28% 95.3M 12s
3350K .......... .......... .......... .......... .......... 29% 91.8M 12s
3400K .......... .......... .......... .......... .......... 29% 91.0M 12s
3450K .......... .......... .......... .......... .......... 30% 107M 12s
3500K .......... .......... .......... .......... .......... 30% 112M 11s
3550K .......... .......... .......... .......... .......... 31% 111M 11s
3600K .......... .......... .......... .......... .......... 31% 108M 11s
3650K .......... .......... .......... .......... .......... 31% 118M 11s
3700K .......... .......... .......... .......... .......... 32% 223K 11s
3750K .......... .......... .......... .......... .......... 32% 102M 11s
3800K .......... .......... .......... .......... .......... 33% 85.8M 11s
3850K .......... .......... .......... .......... .......... 33% 114M 10s
3900K .......... .......... .......... .......... .......... 34% 98.6M 10s
3950K .......... .......... .......... .......... .......... 34% 151M 10s
4000K .......... .......... .......... .......... .......... 34% 91.0M 10s
4050K .......... .......... .......... .......... .......... 35% 106M 10s
4100K .......... .......... .......... .......... .......... 35% 116M 9s
4150K .......... .......... .......... .......... .......... 36% 223K 10s
4200K .......... .......... .......... .......... .......... 36% 126M 9s
4250K .......... .......... .......... .......... .......... 37% 120M 9s
4300K .......... .......... .......... .......... .......... 37% 106M 9s
4350K .......... .......... .......... .......... .......... 38% 108M 9s
4400K .......... .......... .......... .......... .......... 38% 95.3M 9s
4450K .......... .......... .......... .......... .......... 38% 134M 9s
4500K .......... .......... .......... .......... .......... 39% 77.6M 8s
4550K .......... .......... .......... .......... .......... 39% 109M 8s
4600K .......... .......... .......... .......... .......... 40% 116M 8s
4650K .......... .......... .......... .......... .......... 40% 223K 8s
4700K .......... .......... .......... .......... .......... 41% 102M 8s
4750K .......... .......... .......... .......... .......... 41% 140M 8s
4800K .......... .......... .......... .......... .......... 41% 107M 8s
4850K .......... .......... .......... .......... .......... 42% 94.4M 8s
4900K .......... .......... .......... .......... .......... 42% 143M 8s
4950K .......... .......... .......... .......... .......... 43% 97.2M 7s
5000K .......... .......... .......... .......... .......... 43% 89.7M 7s
5050K .......... .......... .......... .......... .......... 44% 122M 7s
5100K .......... .......... .......... .......... .......... 44% 102M 7s
5150K .......... .......... .......... .......... .......... 44% 96.7M 7s
5200K .......... .......... .......... .......... .......... 45% 224K 7s
5250K .......... .......... .......... .......... .......... 45% 113M 7s
5300K .......... .......... .......... .......... .......... 46% 114M 7s
5350K .......... .......... .......... .......... .......... 46% 108M 7s
5400K .......... .......... .......... .......... .......... 47% 126M 7s
5450K .......... .......... .......... .......... .......... 47% 106M 7s
5500K .......... .......... .......... .......... .......... 47% 109M 6s
5550K .......... .......... .......... .......... .......... 48% 123M 6s
5600K .......... .......... .......... .......... .......... 48% 106M 6s
5650K .......... .......... .......... .......... .......... 49% 110M 6s
5700K .......... .......... .......... .......... .......... 49% 118M 6s
5750K .......... .......... .......... .......... .......... 50% 224K 6s
5800K .......... .......... .......... .......... .......... 50% 81.0M 6s
5850K .......... .......... .......... .......... .......... 50% 118M 6s
5900K .......... .......... .......... .......... .......... 51% 98.3M 6s
5950K .......... .......... .......... .......... .......... 51% 113M 6s
6000K .......... .......... .......... .......... .......... 52% 133M 6s
6050K .......... .......... .......... .......... .......... 52% 112M 6s
6100K .......... .......... .......... .......... .......... 53% 109M 5s
6150K .......... .......... .......... .......... .......... 53% 127M 5s
6200K .......... .......... .......... .......... .......... 54% 106M 5s
6250K .......... .......... .......... .......... .......... 54% 108M 5s
6300K .......... .......... .......... .......... .......... 54% 107M 5s
6350K .......... .......... .......... .......... .......... 55% 126M 5s
6400K .......... .......... .......... .......... .......... 55% 119M 5s
6450K .......... .......... .......... .......... .......... 56% 225K 5s
6500K .......... .......... .......... .......... .......... 56% 84.3M 5s
6550K .......... .......... .......... .......... .......... 57% 89.5M 5s
6600K .......... .......... .......... .......... .......... 57% 104M 5s
6650K .......... .......... .......... .......... .......... 57% 114M 5s
6700K .......... .......... .......... .......... .......... 58% 97.8M 5s
6750K .......... .......... .......... .......... .......... 58% 142M 4s
6800K .......... .......... .......... .......... .......... 59% 95.9M 4s
6850K .......... .......... .......... .......... .......... 59% 117M 4s
6900K .......... .......... .......... .......... .......... 60% 117M 4s
6950K .......... .......... .......... .......... .......... 60% 141M 4s
7000K .......... .......... .......... .......... .......... 60% 108M 4s
7050K .......... .......... .......... .......... .......... 61% 31.2M 4s
7100K .......... .......... .......... .......... .......... 61% 90.2M 4s
7150K .......... .......... .......... .......... .......... 62% 139M 4s
7200K .......... .......... .......... .......... .......... 62% 227K 4s
7250K .......... .......... .......... .......... .......... 63% 87.3M 4s
7300K .......... .......... .......... .......... .......... 63% 107M 4s
7350K .......... .......... .......... .......... .......... 63% 113M 4s
7400K .......... .......... .......... .......... .......... 64% 103M 4s
7450K .......... .......... .......... .......... .......... 64% 107M 4s
7500K .......... .......... .......... .......... .......... 65% 150M 4s
7550K .......... .......... .......... .......... .......... 65% 102M 3s
7600K .......... .......... .......... .......... .......... 66% 100M 3s
7650K .......... .......... .......... .......... .......... 66% 112M 3s
7700K .......... .......... .......... .......... .......... 66% 142M 3s
7750K .......... .......... .......... .......... .......... 67% 107M 3s
7800K .......... .......... .......... .......... .......... 67% 106M 3s
7850K .......... .......... .......... .......... .......... 68% 44.1M 3s
7900K .......... .......... .......... .......... .......... 68% 71.6M 3s
7950K .......... .......... .......... .......... .......... 69% 131M 3s
8000K .......... .......... .......... .......... .......... 69% 227K 3s
8050K .......... .......... .......... .......... .......... 69% 108M 3s
8100K .......... .......... .......... .......... .......... 70% 95.3M 3s
8150K .......... .......... .......... .......... .......... 70% 95.5M 3s
8200K .......... .......... .......... .......... .......... 71% 120M 3s
8250K .......... .......... .......... .......... .......... 71% 117M 3s
8300K .......... .......... .......... .......... .......... 72% 127M 3s
8350K .......... .......... .......... .......... .......... 72% 102M 3s
8400K .......... .......... .......... .......... .......... 73% 115M 3s
8450K .......... .......... .......... .......... .......... 73% 126M 2s
8500K .......... .......... .......... .......... .......... 73% 107M 2s
8550K .......... .......... .......... .......... .......... 74% 106M 2s
8600K .......... .......... .......... .......... .......... 74% 109M 2s
8650K .......... .......... .......... .......... .......... 75% 124M 2s
8700K .......... .......... .......... .......... .......... 75% 81.0M 2s
8750K .......... .......... .......... .......... .......... 76% 87.2M 2s
8800K .......... .......... .......... .......... .......... 76% 84.1M 2s
8850K .......... .......... .......... .......... .......... 76% 227K 2s
8900K .......... .......... .......... .......... .......... 77% 95.3M 2s
8950K .......... .......... .......... .......... .......... 77% 155M 2s
9000K .......... .......... .......... .......... .......... 78% 99.5M 2s
9050K .......... .......... .......... .......... .......... 78% 99.5M 2s
9100K .......... .......... .......... .......... .......... 79% 122M 2s
9150K .......... .......... .......... .......... .......... 79% 133M 2s
9200K .......... .......... .......... .......... .......... 79% 109M 2s
9250K .......... .......... .......... .......... .......... 80% 96.6M 2s
9300K .......... .......... .......... .......... .......... 80% 106M 2s
9350K .......... .......... .......... .......... .......... 81% 107M 2s
9400K .......... .......... .......... .......... .......... 81% 143M 2s
9450K .......... .......... .......... .......... .......... 82% 107M 2s
9500K .......... .......... .......... .......... .......... 82% 96.6M 1s
9550K .......... .......... .......... .......... .......... 82% 110M 1s
9600K .......... .......... .......... .......... .......... 83% 138M 1s
9650K .......... .......... .......... .......... .......... 83% 109M 1s
9700K .......... .......... .......... .......... .......... 84% 108M 1s
9750K .......... .......... .......... .......... .......... 84% 125M 1s
9800K .......... .......... .......... .......... .......... 85% 227K 1s
9850K .......... .......... .......... .......... .......... 85% 91.8M 1s
9900K .......... .......... .......... .......... .......... 85% 89.5M 1s
9950K .......... .......... .......... .......... .......... 86% 93.8M 1s
10000K .......... .......... .......... .......... .......... 86% 105M 1s
10050K .......... .......... .......... .......... .......... 87% 128M 1s
10100K .......... .......... .......... .......... .......... 87% 106M 1s
10150K .......... .......... .......... .......... .......... 88% 104M 1s
10200K .......... .......... .......... .......... .......... 88% 133M 1s
10250K .......... .......... .......... .......... .......... 89% 98.3M 1s
10300K .......... .......... .......... .......... .......... 89% 143M 1s
10350K .......... .......... .......... .......... .......... 89% 106M 1s
10400K .......... .......... .......... .......... .......... 90% 105M 1s
10450K .......... .......... .......... .......... .......... 90% 109M 1s
10500K .......... .......... .......... .......... .......... 91% 143M 1s
10550K .......... .......... .......... .......... .......... 91% 107M 1s
10600K .......... .......... .......... .......... .......... 92% 97.5M 1s
10650K .......... .......... .......... .......... .......... 92% 108M 1s
10700K .......... .......... .......... .......... .......... 92% 142M 1s
10750K .......... .......... .......... .......... .......... 93% 228K 1s
10800K .......... .......... .......... .......... .......... 93% 108M 1s
10850K .......... .......... .......... .......... .......... 94% 70.5M 0s
10900K .......... .......... .......... .......... .......... 94% 95.0M 0s
10950K .......... .......... .......... .......... .......... 95% 86.5M 0s
11000K .......... .......... .......... .......... .......... 95% 150M 0s
11050K .......... .......... .......... .......... .......... 95% 107M 0s
11100K .......... .......... .......... .......... .......... 96% 93.4M 0s
11150K .......... .......... .......... .......... .......... 96% 142M 0s
11200K .......... .......... .......... .......... .......... 97% 94.9M 0s
11250K .......... .......... .......... .......... .......... 97% 125M 0s
11300K .......... .......... .......... .......... .......... 98% 98.4M 0s
11350K .......... .......... .......... .......... .......... 98% 136M 0s
11400K .......... .......... .......... .......... .......... 98% 106M 0s
11450K .......... .......... .......... .......... .......... 99% 117M 0s
11500K .......... .......... .......... .......... .......... 99% 108M 0s
11550K .......... .......... . 100% 138M=7.5s
2016-11-03 23:22:04 (1.50 MB/s) - âminotaur-externals-0.2.tar.gzâ saved [11849670/11849670]
configure: WARNING: No solver available, examples will not work.
mkdir: cannot create directory '.libs': File exists
../../../CoinUtils/src/CoinFactorization2.cpp: In member function 'int CoinFactorization::factorDense()':
../../../CoinUtils/src/CoinFactorization2.cpp:520:11: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += (numberDense_+1)/(sizeof(CoinFactorizationDouble)/sizeof(int));
../../../CoinUtils/src/CoinFactorization2.cpp:521:11: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += 2*((numberDense_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinFactorization2.cpp:522:11: warning: conversion to 'CoinBigIndex {aka int}' from 'long unsigned int' may alter its value [-Wconversion]
newSize += ((numberRows_+3)/(sizeof(CoinFactorizationDouble)/sizeof(short)));
../../../CoinUtils/src/CoinLpIO.cpp: In member function 'void CoinLpIO::readLp(FILE*)':
../../../CoinUtils/src/CoinLpIO.cpp:2264:29: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
int length=strlen(buff);
../../../CoinUtils/src/CoinLpIO.cpp:2316:31: warning: conversion to 'int' from 'size_t {aka long unsigned int}' may alter its value [-Wconversion]
int length=strlen(next+1);
../../../CoinUtils/src/CoinStructuredModel.cpp: In member function 'int CoinStructuredModel::decompose(const CoinPackedMatrix&, const double*, const double*, const double*, const double*, const double*, int, int, int*, double)':
../../../CoinUtils/src/CoinStructuredModel.cpp:761:10: warning: variable 'goodDW' set but not used [-Wunused-but-set-variable]
bool goodDW=true;
../../../CoinUtils/src/CoinStructuredModel.cpp:1343:10: warning: variable 'goodBenders' set but not used [-Wunused-but-set-variable]
bool goodBenders=true;
../../../CoinUtils/src/CoinPresolveDual.cpp: In static member function 'static const CoinPresolveAction* remove_dual_action::presolve(CoinPresolveMatrix*, const CoinPresolveAction*)':
../../../CoinUtils/src/CoinPresolveDual.cpp:236:20: warning: unused variable 'lb' [-Wunused-variable]
const double lb = clo[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:237:20: warning: unused variable 'ub' [-Wunused-variable]
const double ub = cup[icol] ;
../../../CoinUtils/src/CoinPresolveDual.cpp:642:13: warning: unused variable 'no_clb' [-Wunused-variable]
const bool no_clb = (active[j]&5)==0 ;
../../../CoinUtils/src/CoinRational.cpp: In member function 'bool CoinRational::nearestRational_(double, double, long int)':
../../../CoinUtils/src/CoinRational.cpp:30:46: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
double mediant = (a + c)/(double(b + d));
../../../CoinUtils/src/CoinRational.cpp:60:30: warning: conversion to 'long int' from 'double' may alter its value [-Wfloat-conversion]
numerator_ += labs(intpart) * denominator_;
../../../CoinUtils/src/CoinRational.cpp:64:52: warning: conversion to 'double' from 'long int' may alter its value [-Wconversion]
return fabs(val - numerator_/double(denominator_)) <= maxdelta;
../../../../Osi/src/Osi/OsiSolverInterface.cpp: In member function 'int OsiSolverInterface::differentModel(OsiSolverInterface&, bool)':
../../../../Osi/src/Osi/OsiSolverInterface.cpp:1880:8: warning: unused variable 'gotHint' [-Wunused-variable]
bool gotHint = (getHintParam(OsiDoReducePrint,takeHint,strength));
libtool: install: warning: relinking `libOsi.la'
libtool: install: warning: relinking `libOsiCommonTests.la'
../../../Clp/src/ClpPlusMinusOneMatrix.cpp:459:13: warning: 'doPlusOnes' defined but not used [-Wunused-variable]
static bool doPlusOnes=true;
../../../Clp/src/ClpSimplex.cpp: In member function 'int ClpSimplex::fathom(void*)':
../../../Clp/src/ClpSimplex.cpp:11081:15: warning: unused variable 'statusWeights' [-Wunused-variable]
int statusWeights = fastDual2(info);
../../../Clp/src/ClpSimplexOther.cpp: In member function 'int ClpSimplexOther::setInDual(ClpSimplex*)':
../../../Clp/src/ClpSimplexOther.cpp:1313:12: warning: unused variable 'statusD' [-Wunused-variable]
Status statusD = dualProblem->getRowStatus(iColumn);
../../../Clp/src/ClpSimplexOther.cpp:1314:12: warning: unused variable 'statusDJ' [-Wunused-variable]
Status statusDJ = dualProblem->getColumnStatus(jColumn);
../../../Clp/src/ClpSimplexOther.cpp:1352:12: warning: unused variable 'statusD' [-Wunused-variable]
Status statusD = dualProblem->getColumnStatus(iRow);
../../../Clp/src/ClpSolver.cpp: In function 'void statistics(ClpSimplex*, ClpSimplex*)':
../../../Clp/src/ClpSolver.cpp:3756:10: warning: variable 'numberWritten' set but not used [-Wunused-but-set-variable]
size_t numberWritten;
libtool: install: warning: relinking `libClp.la'
libtool: install: warning: relinking `libClpSolver.la'
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::initialSolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:148:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'virtual void OsiClpSolverInterface::resolve()':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:843:8: warning: variable 'gotHint' set but not used [-Wunused-but-set-variable]
bool gotHint = (getHintParam(OsiDoInBranchAndCut,takeHint,strength));
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp: In member function 'int OsiClpSolverInterface::infeasibleOtherWay(char*)':
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9967:22: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
whichWay[iColumn] *=2;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9972:22: warning: conversion to 'char' from 'int' may alter its value [-Wconversion]
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9822:7: warning: unused variable 'iRow' [-Wunused-variable]
int iRow,iColumn;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9840:17: warning: unused variable 'objective' [-Wunused-variable]
const double *objective = getObjCoefficients() ;
../../../../Clp/src/OsiClp/OsiClpSolverInterface.cpp:9841:10: warning: unused variable 'direction' [-Wunused-variable]
double direction = getObjSense();
libtool: install: warning: relinking `libOsiClp.la'
ar: creating libbqpd.a
filteraux.f:105.24:
. 0.D0,.false.)
1
Warning: Rank mismatch in argument 'w' at (1) (rank-1 and scalar)
ar: creating libfiltersqp.a
ar: creating amplsolver.a
/home/amahajan/tmp/minotaur-test/scripts/build_externals: line 189: cd: minotaur-externals//build: No such file or directory
make: *** No rule to make target 'distclean'. Stop.
: logger ok! OK (39)
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Thu Nov 3 23:25:04 IST 2016
More information about the Minotaur-dev
