[Minotaur-dev] minotaur daily test results
amahajan
amahajan at iitb.ac.in
Tue Nov 1 12:24:39 CDT 2016
Minotaur daily test report
Tue Nov 1 22:37:02 IST 2016
origin.ieor.iitb.ac.in
Linux origin 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u1 (2016-09-03) x86_64 GNU/Linux
Detailed log available at http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (39)
compiling build-base-static: OK.
make utest output for build-base-static: OK (39)
compiling build-filter: OK.
make utest output for build-filter: OK (39)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (39)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (39)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (42)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (42)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (42)
compiling build-osi: OK.
make utest output for build-osi: OK (39)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (39)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (39)
compiling build-ampl: OK.
make utest output for build-ampl: OK (58)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (58)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (58)
compiling build-all: OK.
make utest output for build-all: OK (69)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (69)
compiling build-all-static: OK.
make utest output for build-all-static: OK (69)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
/usr/bin/ld: Warning: alignment 16 of symbol `epsc_' in /home/amahajan/tmp/minotaur-test/minotaur-externals/bqpd-3/libbqpd.a(bqpd.o) is smaller than 64 in /home/amahajan/tmp/minotaur-test/minotaur-externals/filter-102/src/libfiltersqp.a(QPsolves.o)
/usr/bin/ld: Warning: alignment 16 of symbol `wsc_' in /home/amahajan/tmp/minotaur-test/minotaur-externals/bqpd-3/libbqpd.a(bqpd.o) is smaller than 64 in /home/amahajan/tmp/minotaur-test/minotaur-externals/filter-102/src/libfiltersqp.a(filter.o)
/usr/bin/ld/:usr /Warningbin:/ ldalignment: 16Warning :of alignmentsymbol 16` epsc_of' symbolin `/epsc_home'/ amahajanin/ tmp//homeminotaur/-amahajantest//tmpminotaur/-minotaurexternals-/testbqpd/-minotaur3-/externalslibbqpd.a/(bqpdbqpd.o-)3 /islibbqpd.a (smallerbqpd.o )than is64 smallerin than/ home64/ amahajanin/ tmp//homeminotaur/-amahajantest//tmpminotaur/-minotaurexternals-/testfilter/-minotaur102-/externalssrc//filterlibfiltersqp.a-(102QPsolves.o/)src
//libfiltersqp.ausr(/QPsolves.obin)/
ld/:usr /Warningbin:/ ldalignment: 16Warning :of alignmentsymbol 16` wsc_of' symbolin `/wsc_home'/ amahajanin/ tmp//homeminotaur/-amahajantest//tmpminotaur/-minotaurexternals-/testbqpd/-minotaur3-/externalslibbqpd.a/(bqpdbqpd.o-)3 /islibbqpd.a (smallerbqpd.o )than is64 smallerin than/ home64/ amahajanin/ tmp//homeminotaur/-amahajantest//tmpminotaur/-minotaurexternals-/testfilter/-minotaur102-/externalssrc//filterlibfiltersqp.a-(102filter.o/)src
: logger ok! OK (69)
==30159== Memcheck, a memory error detector
==30159== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==30159== Using Valgrind-3.10.0 and LibVEX; rerun with -h for copyright info
==30159== Command: ./unittest all
==30159==
==30159==
==30159== HEAP SUMMARY:
==30159== in use at exit: 0 bytes in 0 blocks
==30159== total heap usage: 170,795 allocs, 170,795 frees, 888,031,086 bytes allocated
==30159==
==30159== All heap blocks were freed -- no leaks are possible
==30159==
==30159== For counts of detected and suppressed errors, rerun with: -v
==30159== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:534: minotaur.d: No such file or directory
/home/amahajan/tmp/minotaur-test/src/base/MsProcessor.cpp:13:5: warning: "USE_OPENMP" is not defined [-Wundef]
#if USE_OPENMP
/home/amahajan/tmp/minotaur-test/src/base/MsProcessor.cpp:697:5: warning: "USE_OPENMP" is not defined [-Wundef]
#if USE_OPENMP
/home/amahajan/tmp/minotaur-test/src/base/MsProcessor.cpp:719:5: warning: "USE_OPENMP" is not defined [-Wundef]
#if USE_OPENMP
/home/amahajan/tmp/minotaur-test/src/base/MsProcessor.cpp:839:5: warning: "USE_OPENMP" is not defined [-Wundef]
#if USE_OPENMP
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (58)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (39)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
: logger ok! OK (42)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Tue Nov 1 22:54:39 IST 2016
More information about the Minotaur-dev
