[Minotaur-dev] minotaur daily test results
amahajan amahajan at iitb.ac.in
Sat Dec 31 11:24:44 CST 2016
Minotaur daily test report
Sat Dec 31 22:37:02 IST 2016
origin.ieor.iitb.ac.in
Linux origin 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
Detailed log available at  http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2-131-g22e39d9
Summary
compiling build-base: OK.
make utest output for build-base: OK (39)
compiling build-base-debug: OK.
make utest output for build-base-debug: OK (39)
compiling build-base-static: OK.
make utest output for build-base-static: OK (39)
compiling build-filter: OK.
make utest output for build-filter: OK (39)
compiling build-filter-debug: OK.
make utest output for build-filter-debug: OK (39)
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (39)
compiling build-ipopt: OK.
make utest output for build-ipopt: OK (42)
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: OK (42)
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (42)
compiling build-osi: OK.
make utest output for build-osi: OK (39)
compiling build-osi-debug: OK.
make utest output for build-osi-debug: OK (39)
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (39)
compiling build-ampl: OK.
make utest output for build-ampl: OK (58)
compiling build-ampl-debug: OK.
make utest output for build-ampl-debug: OK (58)
compiling build-ampl-static: OK.
make utest output for build-ampl-static: OK (58)
compiling build-all: OK.
make utest output for build-all: OK (69)
compiling build-all-debug: OK.
make utest output for build-all-debug: OK (69)
compiling build-all-static: OK.
make utest output for build-all-static: OK (69)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
: logger ok! OK (69)
==18078== Memcheck, a memory error detector
==18078== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
==18078== Using Valgrind-3.10.0 and LibVEX; rerun with -h for copyright info
==18078== Command: ./unittest all
==18078==
==18078==
==18078== HEAP SUMMARY:
==18078==     in use at exit: 0 bytes in 0 blocks
==18078==   total heap usage: 171,387 allocs, 171,387 frees, 888,058,741 bytes allocated
==18078==
==18078== All heap blocks were freed -- no leaks are possible
==18078==
==18078== For counts of detected and suppressed errors, rerun with: -v
==18078== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
Errors in build-all:
Errors in build-all-manual:
Makefile:542: minotaur.d: No such file or directory
Errors in build-all-static:
Errors in build-ampl-debug:
: logger ok! OK (58)
Errors in build-ampl:
Errors in build-ampl-static:
Errors in build-base-debug:
: logger ok! OK (39)
Errors in build-base:
Errors in build-base-static:
Errors in build-filter-debug:
Errors in build-filter:
Errors in build-filter-static:
Errors in build-ipopt-debug:
: logger ok! OK (42)
Errors in build-ipopt:
Errors in build-ipopt-static:
Errors in build-osi-debug:
Errors in build-osi:
Errors in build-osi-static:
End of tests
Sat Dec 31 22:54:44 IST 2016
More information about the Minotaur-dev mailing list
