[AG-TECH] AG 3.0.2 rpm installation writing to /etc/AccessGrid3 instead of .Accessgrid3
Doug Baggett
dbaggett at nsf.gov
Wed Nov 15 14:33:53 CST 2006
I tried to store an updated configuration on a Fedora core 6 system with
the RPM package of AG 3.0.2 and it keeps trying to store the prefs into
the global /etc config directory (which it does not have write access
to) instead of the local .Accessgrid3 directory.
> Traceback (most recent call last):
> File "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/AGNodeService.py", line 538, in StoreConfiguration
> raise Exception("Can't write config file %s" % (fileName))
> Exception: Can't write config file /etc/AccessGrid3/Config/nodeConfig/default
Why would it do that? Now I could fix the problem by giving it write access to /etc/AccessGrid3
that definitely is not the right solution.
Suggestions?
thanks!
-DougB
CISE/NSF
More information about the Kenstest
