[Fwd: Re: [AG-TECH] agtk 3.0.2 and Windows XP64]
Thomas D. Uram
turam at mcs.anl.gov
Fri Nov 10 10:37:49 CST 2006
I'm forwarding Paul's response to the list to close the loop on whether
AG3 works on XP64.
-------- Original Message --------
Subject: Re: [AG-TECH] agtk 3.0.2 and Windows XP64
Date: Fri, 10 Nov 2006 15:26:44 -0000
To: Thomas D. Uram <turam at mcs.anl.gov>
References: <455459F6.30747.88269D at P.S.Hatton.bham.ac.uk>
Hi tom,
File attached. The first line gave it away - couldn't get an IP
address. The user uninstalled the toolkit, renewed the IP lease and
re-installed; it's fine now.
This machine is dual-hosted, one with a private connection down to
our NAS, so it may have been internally confused.
Thanks
On 10 Nov 2006 at 9:01, Thomas D. Uram wrote:
> Hi Paul:
> There may be a VenueClient.log file in
> C:\Documents and Settings\<username>\Application Data\AccessGrid3\Logs
> the content of which may indicate the problem. If the problem is not
> evident to you or the user, you could send it (privately) for me to look
> at. If there is no such file, do this:
> - Open a command shell
> - cd C:\Program Files\AGTk-3\bin
> - run VenueClient3.py --debug
> and send the text that is displayed.
> Tom
> On 11/10/06 4:52 AM, Paul Hatton wrote:
> > Has anyone got AGTK 3.0.2 running on 64-bit XP on Intel (or AMD for
> > that matter, but we're currently on Intel EM64T in HP xw8200s for our
> > 64-bit workstations)? One of our users reports that it fails on
> > startup, probably with a python issue, but no error message. AGTK 2.4
> > is OK on this platform. Note this isn't asking about Itanium.
> > The Access Grid Support Centre here (UK) is planning to withdraw
> > their AGTK2 server/bridge soon, so I wonder if they have tested AGTK3
> > on x64?
> > Thanks
Paul Hatton
High Performance Computing and Visualisation Specialist
Technical Director, HP Visual and Spatial Technology Centre
Information Services, Elms Road Computer Centre,
The University of Birmingham, Birmingham B15 2TT.
Ph: 0121-414-3994 Fax: 0121-414-3952 Mob: 07785 977430
More information about the Kenstest
