[AG-TECH] Webcam Configuration with VIC
aspale1
aspale1 at lac.uic.edu
Mon Jul 25 16:17:38 CDT 2005
Hello,
I have been in the process of trying to get my Creative Webcam Live Ultra
to work with VIC. I frequently received an error message that started with
"Microsoft Visual C++ Runtime Library Runtime Error!". I came across an
old e-mail that had the answer to my problem (though it is not very
elegant) that can be found here:
http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2004/03/msg00334.html.
I would like to know if there is a way that I can specify certain VIC
settings in the AG configuration where I could specify the webcam capture
resolution (352x288) that will be sent to VIC or "permanently" set the VIC
option of "Configure on Transmit" so that I can receive a dialog box that
will allow me to set the mentioned resolution? If I can save this webcam
resolution setting using my webcam software, could this information
somehow be sent to the AG software which then would be sent to VIC?
When I have used the VRVS software with my webcam, I do not receive any
configuration errors. Depending on the type of user I am, I will either
receive the webcam configuration dialog box that will allow me to set the
appropriate resolution or the VRVS VIC somehow "remembers" the webcam
resolution setting and transmits without a problem. Is what I am trying to
already possible?
Thanks.
Allan
National Center for Data Mining
University of Illinois at Chicago
More information about the Kenstest
