[AG-TECH] Gentner AP400
Jeremy Mann
jeremy at biochem.uthscsa.edu
Mon Jul 18 09:57:20 CDT 2005
I'm so close to getting this thing to work. I finally got the serial
working and setup the machine exactly like the document shows. However,
echo cancelling was still not working, so I built a custom Preset 1 that
worked.
Several problems occured however, the audio out was extremely low. I had
the gain for Output D cranked all the way up and we could barely hear the
talking. Second, the mic inputs were somehow overloaded and would
constantly clip. Adjusting the levels didn't work, it was either
overloaded or too soft to pick up anything.
Natalia Costas Lago said:
> There's a pinout scheme for the XAP400 serial cable, probably there's one
> for the AP400. Make a cable with the exact pinout, just to be sure u r
> using
> the right one.
> From: "Jeremy Mann" <jeremy at biochem.uthscsa.edu>
> To: "John Hodrien" <johnh at comp.leeds.ac.uk>
> Cc: <ag-tech at mcs.anl.gov>
> Sent: Wednesday, July 06, 2005 3:36 PM
> Subject: Re: [AG-TECH] Gentner AP400
>> John Hodrien said:
>>> On Tue, 5 Jul 2005, Darin Oman wrote:
>>>> Hi Jeremy,
>>>> Are you sure the serial port on the computer is enabled/working?
>>> ClearOne recommended disabling the hardware flow control when we had
>>> problems
>>> with connecting to the device.
>> Thanks John, but I tried all the settings in the RS232 menu and it still
>> didn't work. I'm going to try some cables. I know the cable from our
>> managed switch works so I'm going to try that cable next.
>> Jeremy Mann
>> University of Texas Health Science Center
>> Bioinformatics Core Facility
>> http://www.bioinformatics.uthscsa.edu
>> Phone: (210) 567-2672
Jeremy Mann
More information about the Kenstest
