[AG-TECH] Multi Display Cards Recommendation
Derek Piper
dcpiper at indiana.edu
Fri Jul 15 08:12:12 CDT 2005
Natalia makes a very good point, you'd end up saturating the PCI bus.
We also had sluggish response with the NVidia Quadro when windows were
filling the screens and I'm betting it was saturating the PCI bus. I
changed to a Matrox QID (AGP) for our 2x2 display and things work great.
Derek
Natalia Costas Lago wrote:
> I havent tried but... r u sure u wanna do that?
> The PCI bus maximun data transfer is 132 MB (shared by all the slots),
> I'm unsure the performance problem we got with the Nvidia Quadro NVS
> (that is a Quad PCI card) was that particular limit or other.
> Maybe two dual cards? one PCI and an AGP? (if u plan to use OpenGL or
> something... does it work in both cards?, maybe the one that was
> installed?... I'm not sure about these issues).
> ----- Original Message ----- From: "Jim Miller"
> <millerjw at mailer.rr.psc.edu>
> To: "Natalia Costas Lago" <natalia at cesga.es>
> Cc: "Peter DeSantis" <peter at jumbovision.com.au>; "John I Quebedeaux Jr"
> <johnq at lsu.edu>; "Derek Piper" <dcpiper at indiana.edu>; "Todd Zimmerman"
> <toddz at sfu.ca>; "'ag-tech'" <ag-tech at mcs.anl.gov>; "Westgrid-AGTECH"
> <westgrid-agtech-l at majordomo.netera.ca>
> Sent: Thursday, July 14, 2005 4:41 PM
> Subject: Re: [AG-TECH] Multi Display Cards Recommendation
>> I am working on this issue with Matrox pretty closely. See my forum
>> thread here.
>> http://forum.matrox.com/mga/viewtopic.php?t=16219
>> So this can be solved with an upgrade to the VIC?
>> Another question about Multimonitor... I am ready at this point to junk
>> the matrox cards and get 4 individual PCI video cards. My display box
>> has
>> plenty of empty PCI. Is anyone using this approach and which cards do
>> you
>> find to work the best?
>> Thanks,
>> Jim
>>> We bought a Matrox QID PCIe Low Profile and got the same problem. It
>>> seems we found a workaround that was to replace VIC 1.1.3 by VIC
>>> 1.1.6 (i got this version from UCL mbone tools that is more or less
>>> the same but a few changes).
>>> ----- Original Message ----- From: "Peter DeSantis"
>>> To: "John I Quebedeaux Jr" <johnq at lsu.edu>
>>> Cc: "Derek Piper" <dcpiper at indiana.edu>; "Todd Zimmerman"
>>> Sent: Tuesday, July 12, 2005 3:41 AM
>>> Subject: re[4]: [AG-TECH] Multi Display Cards Recommendation
>>>> We used XP sp2, Asus mainboards, 3.0ghz intel cpu etc etc.
>>>> Im sure i sure 1 or 2 posts from someone else about this issue and
>>>> that there possibly was a fix, but we never tested it out.
>>>> I think the post stated links to 2 upgraded versions of vic that
>>>> they stated fixed the problem, but it wasnt clear that they were in
>>>> fact running in independentat screen mode to see the problem.
>>>> As for the resolution matrox claim there is a tool on thier wesbite
>>>> that allows you to add this custom resoltuion, but i aint testededd it.
>>>> For what it is worth my opinion is that if you aint gonna use one of
>>>> the vic variations that allow greater than 388x252 pixel capture you
>>>> should not look to use anyhting higher than 1280x1024.
>>>> Peter
>>>> >> Hi Peter, I realize this is a month later... but going back
>>>> through
>>>> >> messages I found yours.
>>>> >> Well, I can confirm this behavior as well with the product now
>>>> having >> just
>>>> >> gotten the card in one of our nodes to try. I haven't tried that
>>>> >> resolution though, but have the screen corruption you talked
>>>> about. >> Did
>>>> >> it happen with any other application besides Vic?Any fix to this
>>>> >> problem?
>>>> >> Seemed to duplicate from screens 1 to 2 and 3 to 4. So we had to
>>>> >> resort
>>>> >> to the stretch mode and since our setup was just 2 projectors
>>>> and 2
>>>> >> monitors we went with 2x2 such that the windows taskbar stayed
>>>> on >> the
>>>> >> operator monitors and had to drag stuff "up" to the projectors. >>
>>>> Annoying
>>>> >> for me, but worked.
>>>> >> Which OS were you doing this on?
>>>> >> Thanks, John Q.
>>>> >> -- >> John I. Quebedeaux, Jr.
>>>> >> Louisiana State University
>>>> >> Computer Manager / LBRN & CCT / 131 Life Sciences Bldg. & 339
>>>> Johnston
>>>> >> Hall
>>>> >> e-mail: johnq at lsu.edu or johnq at cct.lsu.edu / web:
>>>> http://lbrn.lsu.edu >> &
>>>> >> http://cct.lsu.edu
>>>> >> phone: 225-578-0062 / fax: 225-578-2597
>>>> >> On Jun 9, 2005, at 8:49 PM, Peter DeSantis wrote:
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
More information about the Kenstest
