[AG-TECH] more on multi-input capture.
Fred Dech
fdech at uchicago.edu
Wed Jul 13 15:10:07 CDT 2005
that is unless you get a set of cards or card that still use VFW drivers,
like the older Winnov Videum cards we are currently using.
--fred
On Wed, Jul 13, 2005 at 02:54PM, Derek Piper said:
> It will happen regardless of the type of capture device, just so
> that's clear. If you have more than one device that captures video, if it's
> a USB camera or capture card, then you'll have that problem with Windows.
> Derek
> Fred Dech wrote:
> >hi Derek.
> >i see. that's useful information. the EVERY TIME clause is a real
> >drag, though. in the case i'm thinking about, using linux is not an
> >option.
> >thanks, though.
> >--fred
> >On Wed, Jul 13, 2005 at 02:15PM, Derek Piper said:
> >> No, I explained how that part works my previous post. Maybe a
> >> diagram would be good.
> >>VIC -> 'Microsoft WDM Image Capture' -> Source0
> >>VIC -> 'Microsoft WDM Image Capture' -> Source1
> >>VIC -> 'Microsoft WDM Image Capture' -> Source2
> >>VIC -> 'Microsoft WDM Image Capture' -> Source3
> >> VIC only binds to 'Microsoft WDM Image Capture', *it doesn't know
> >> about the sources beyond that*. Upon invocation, the WDM driver will
> >> choose the first 'source' it can find, since none was given. This leads
> >>to all four VICs choosing Source0 (probably) and 3 of them will not be
> >>able to get it and will complain by putting up a selector box to choose
> >>another source. So, you go ahead and choose another source, i.e. Source1
> >>for the first one you have to alter, then Source2 for the other one etc.
> >>All 4 VICs will then be up and running. Unfortunately you will need to do
> >>this EVERY TIME you change venues. If it drives you crazy, use a Linux
> >>box for video from multiple sources.
> >> Derek
> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> IRI 323, School of Informatics
> Indiana University, Bloomington, Indiana
More information about the Kenstest
