[AG-TECH] more on multi-input capture.
Fred Dech
fdech at uchicago.edu
Tue Jul 12 16:52:57 CDT 2005
thanks, Derek.
but what i don't understand is this.
if the Spectra8 currently uses WDM drivers in Windows...
VIC relies on VFW type drivers. that's what the problem is/was with the
newer WDM driver Winnov Videum cards and VIC.
i'm missing something.
--fred
On Tue, Jul 12, 2005 at 04:38PM, Derek Piper said:
> Hi,
> Having installed a Spectra8 after using a WinTV 150PVR, I can tell
> you it's *very easy* to get going. Yes, each input installs a driver
> individually (4 goes round the 'found new hardware' wizard - yawn, but
> once it's done it's done). After that it just works like 4 individual
> capture cards. As mentioned before, the inherent problem with VIC not
> being able to differentiate between the sources and 'colliding' over
> what input to use still remains, but that's Windows thing and happens
> any time there is more than one capture device. You just have to select
> the 'other' source(s), whatever they may be, when the window prompts you
> and all sources will come up nicely.
> Spectra8 cards, being 4 BT878 chips, would work nicely under Linux
> and not suffer from that problem (they'd just be /dev/video0, /dev/video1
> etc.), although I have not personally tested it.
> Derek
> Fred Dech wrote:
> >this has been covered in various ways at various times. but i've got
> >a new question on this subject.
> >we had a problem with the last Winnov Videum card we spec'd for another
> >institution because before they purchased the card the Videum been upgraded
> >to WDM drivers. while the VFW drivers would make it work right for AG,
> >this
> >other institution needed to use the software that came with the capture
> >card.
> >i've noticed quite a few posts by people successfully using the Spectra8
> >4 input card. so i've now come to the point of replacing that Winnov
> >Videum with something that will cover all the needs of our collaborators;
> >proprietary capture software and AG.
> >i'm looking at a web page with Spectra8 specifications. i'm very, very
> >surprised to see, "... each frame grabber channel has it's own WDM driver,
> >allowing you to capture from 4 individual video channels."
> >now i'm really confused. is the WDM driver relatively recent for the
> >Spectra8? it must be... or how have people made it work well with AG...
> >any insights would be greatly appreciated.
> >--fred
> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> IRI 323, School of Informatics
> Indiana University, Bloomington, Indiana
More information about the Kenstest
