[AG-TECH] video capture
Randy Groves randy.groves at boeing.com
Thu Oct 21 19:42:17 CDT 2004
I believe that the Osprey 210 cards will also work in PCI-X.
-randy
At 04:39 PM 10/21/2004, Patrick Johnson wrote:
>Victor,
>You are my hero!  Going to that unsupported kernel worked.
>I ran “xawtv –noxv” and I got video (There seems to be some color issues,
>though).
>I’m using the Hauppage WinTV Radio cards (BT878) but I’m going to need to
>get 4 Pinnacle PCTV-PRO(s) instead, since I only have PCI-X slots remaining.
>Thanks again for your help,
>Patrick Johnson
>Integrated Media Systems
>1260 N. Fee Ana
>Anaheim, CA 92807
>office: 714-579-4100
>cell: 714-225-0666
>pjohnson at imsav.com
>From: Victor M. Babson, Jr. [mailto:vbabson at secsg.uga.edu]
>Sent: Thursday, October 21, 2004 3:02 PM
>To: Patrick Johnson
>Subject: Re: [AG-TECH] video capture
>Patrick,
>I would recommend using the link I sent you ONLY if the kernel-unsupported
>rpm from <https://rhn.redhat.com>https://rhn.redhat.com doesn't work for you.
>--Vic
>----- Original Message -----
>From: <mailto:pjohnson at imsav.com>Patrick Johnson
>To: <mailto:vbabson at secsg.uga.edu>Victor M. Babson, Jr. ;
><mailto:ag-tech at mcs.anl.gov>ag-tech at mcs.anl.gov
>Sent: Thursday, October 21, 2004 5:52 PM
>Subject: RE: [AG-TECH] video capture
>I took out the [1] in the name and got the following error.
>%rpm –ivh kernel-unsupported-2.4.21-20.EL.i686.rpm
>Error: kernel-unsupported-2.4.21-20.EL.i686.rpm cannot be installed
>I am running as root and I on the 2.4.21-20.EL kernel
>Thanks,
>Patrick Johnson
>1260 N. Fee Ana
>Anaheim, CA 92807
>cell: 714-225-0666
><mailto:pjohnson at imsav.com>pjohnson at imsav.com
>Sent: Thursday, October 21, 2004 2:33 PM
>To: Patrick Johnson
>Got me!  Maybe rename the file taking out the [1].
>Also, are you running kernel 2.4.21.20 when trying to install?  If you are
>running 2.4.21.15, that might break it...
>Here's the output from my box:
>[vbabson at rvideo vbabson]$ rpm -qa |grep kernel
>kernel-2.4.21-4.EL
>kernel-unsupported-2.4.21-15.EL
>kernel-utils-2.4-8.37.3
>kernel-source-2.4.21-15.EL
>kernel-smp-2.4.21-4.EL
>kernel-smp-2.4.21-15.EL
>kernel-2.4.21-15.EL
>kernel-pcmcia-cs-3.1.31-13
>Let me know if you get anywhere....
>--Vic
>Sent: Thursday, October 21, 2004 5:11 PM
>Thank you, Vic.
>I downloaded the kernel-unsupported-2[1].4.21-20.EL.i686.rpm from your
>webserver and ran (as root)
>% rpm –ivh  kernel-unsupported-2[1].4.21-20.EL.i686.rpm
>It returned with the following error
>Error: File not found by glob: kernel-unsupported-2[1].4.21-20.EL.i686.rpm
>What am I doing wrong?
>I ran a “rpm –qa | grep kernel” and found that I have the following kernel
>packages already installed.
>Kernel-2.4.21-15.EL
>Kernel-2.4.21-20.EL
>Kernel-source-2.4.21-20.EL
>Kernel-utils-2.4-8.37.6
>Kernel-pcmcia-cs-3.1.31-13
>Do I need to upgrade any of these first?
>Thanks,
>Patrick Johnson
>1260 N. Fee Ana
>Anaheim, CA 92807
>cell: 714-225-0666
>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>Behalf Of Victor M. Babson, Jr.
>Sent: Wednesday, October 20, 2004 11:47 AM
>To: ag-tech at mcs.anl.gov
>Patrick,
>I've successfully setup AG 2.2 on RHEL WS3.
>You need to install the kernel-unsupported-2.4.21-xx package.
>I have it on a webserver where you can grab it or just pull it from
>redhat's site:
><http://vic.secsg.org/kernel-unsupported-2%5b1%5d.4.21-20.EL.i686.rpm>http://vic.secsg.org/kernel-unsupported-2[1].4.21-20.EL.i686.rpm
>After installing, you might have to run a
>"modprobe bttv"
>then bttv should show up when you
>"lsmod"
>Let me know if I can offer any more help:)
>If you get AG 2.3 loaded, please let me know about it.  I couldn't get it
>to work, so I moved to Debian...  I'm working out a hostname problem right
>now, but at least the install worked.
>--Vic
>To: <mailto:ag-tech at mcs.anl.gov>ag-tech at mcs.anl.gov
>Sent: Wednesday, October 20, 2004 2:29 PM
>Subject: [AG-TECH] video capture
>I’m attempting to install a Hauppauge WINTV RADIO pci card (BT878 chipset)
>on my RedHat Enterprise Linux WS version 3.  The driver for the card is
>the bttv driver.  From my research about the driver it is suppose to be
>built into the Linux kernel.  I’m running Kernel
>2.4.21-20EL-i686.  RedHat’s hardware browser shows the card as a video
>capture card and defines the driver as bttv.  However the card is not
>“mapped” to a device.  I tried running
>% xawtv –noxv
>And it returned
>Can’t open /dev/video0
>I don’t really now how to troubleshoot this as I’m still a novice Linux user.
>I looked under /lib/modules/<Kernel version>/Kernel/drivers and I didn’t
>see the bttv module.  When I try to modprobe for bttv it returns an error
>saying it can’t locate the module.
>However, when I look under /usr/src/linux-2.4.21-20.EL/drivers/media/video
>I do see the bttv module source.
>Do I need to rebuild the Kernel?  I don’t know how to tell if the bttv
>driver is already there and I don’t know how to rebuild the kernel
>either.  I apologize if this is the wrong mailing list to be asking this
>type of question but if it is could you direct me to where I can get help?
>Thanks,
>Patrick
>Patrick Johnson
>1260 N. Fee Ana
>Anaheim, CA 92807
>cell: 714-225-0666
More information about the Kenstest mailing list
