[AG-TECH] Anonymous and NTP
Thomas D. Uram
turam at mcs.anl.gov
Wed Oct 20 21:30:37 CDT 2004
Jeremy:
The message you're getting is shown when the time could not be retrieved
from the ntp server. If you're confident that the time is not a
problem, I'd suspect a problem with the anonymous certificate, or with
the anonymous CA certificate in the certificate repository of the user
running the venue server.
You should check the cert repo of the user running the venue server and
the venue client for the presence of the anonymous ca cert. If the CA
cert is missing, the certificate status will be 'Invalid CA chain'.
There should also be an indication of the problem in the VenueServer.log
or VenueClient.log; if the problem isn't clear there, you can send the
relevant portion of the logfile to me.
Tom
Jeremy Mann wrote:
> This is about the fifth time I've posted this message, so I'm trying
> again. When using an Anonymous certificate I get a NTP time error message
> when trying to connect to our VenueServer. Switching to a users
> certificate works perfectly. Both the client and the server sync from our
> NTP server.
> The exact error is:
> Authorization failure connecting to server. Please check the time on your
> computer; an incorrect local clock can cause authorization to fail.
> The time on BOTH client and server are exact.
> However, when connecting to the ANL venue server, everything works perfectly.
> Can somebody help me on this?
More information about the Kenstest
