[AG-TECH] Gentoo or Fedora
Monika Rabarison
monika.k.rabarison at ccaix.jsums.edu
Mon Oct 18 11:21:41 CDT 2004
Gavin,
Could you email the steps you took for building the ALSA driver?
TIA,
Monika
On Mon, 18 Oct 2004, Gavin W. Burris aka 86 wrote:
> I do recommend Debian over Gentoo. I have to agree with Ivan. I
> would not use Gentoo as a production system. But I admit my bias for
> Debian. Though I came to this bias because I have found Debian easier
> to maintain in a production environment, as well as for personal use
> and experimentation, mostly due to the package management and the
> Social Contract of Debian/GNU Linux.
> The Gotcha with Debian is to install ALSA sound drivers. In Linux,
> the ALSA sound drivers are much better than the default OSS drivers.
> I had to install the kernel-source package and built my own kernel,
> then build the alsa-source package against it. Not really a big deal.
> I'll email you the steps I took If you like. Maybe I should include
> this info on my webpages?
> I had no bugs. :) Even my multiple video capture devices worked
> "out of the box". You do have to wrap your head around the ALSA
> mixer settings, though.
> Victor M. Babson, Jr. wrote (on Mon, 18 Oct 2004 at 10:14):
> > Gavin,
> > I'm about to change the OS from RHEL WS3 to Gentoo in order to get some
> > bug-fixes in the 2.3 version. I've tried installing 2.3 on the current OS,
> > but no dice.
> > I use Debian for a number of things on a number of machines. I've never
> > tried installing the AGTk. Are there any gotcha's? Some bugs that you've
> > found but can deal with?? Examples?
> > Would you recommend Debian over Gentoo for AG, or were you just throwing
> > this out there so people know that someone has done it?
> > Thanks for your advice/time.
> > --Vic
> > ----- Original Message -----
> > From: "Gavin W. Burris aka 86" <ga5in at psu.edu>
> > To: "Steve Smith" <ssmith at vislab.usyd.edu.au>
> > Cc: "Monika Rabarison" <monika.k.rabarison at ccaix.jsums.edu>;
> > <ag-tech at mcs.anl.gov>
> > Sent: Monday, October 18, 2004 9:50 AM
> > Subject: Re: [AG-TECH] Gentoo or Fedora
> > > I second the suggestion for Debian. I just reinstalled my room based
> > > node with my audio and video machines with Debian. Please feel free
> > > to send me questions.
> > > I recommend you use the pre-rc2 netinst CD image:
> > > http://www.debian.org/devel/debian-installer/
> > http://cdimage.debian.org/pub/cdimage-testing/sid_d-i/i386/pre-rc2/sarge-i386-netinst.iso
> > > Cheers.
> > > Steve Smith wrote (on Sat, 16 Oct 2004 at 15:32):
> > > > Monika Rabarison wrote:
> > > > > Hi all,
> > > > > Thinking about upgrading the "good old" Linux capture boxes to 2.3,
> > > > > what would you guys suggest Gentoo or Fedora? Any pros and cons?
> > > > Another option is Debian (AG packages available at
> > > > http://www.vislab.usyd.edu.au/debian). The main pros are those of
> > > > Debian: ease of upgrade (no need to do re-installs), good security
> > > > support, large number of supported packages. The main con has
> > > > traditionally been the difficulty of installation (this is much better
> > > > with the recent beta installers). Also, the next stable release isn't
> > > > actually out yet, although it should be soon.
> > > > There are also packages available for Slackware, which has good support
> > > > and a shorter release cycle if you prefer that.
> > > > Cheers,
> > > > Steve
> > > Senior Systems Programmer
> > > Penn State Visualization Group
> > > http://viz.aset.psu.edu/ga5in
More information about the Kenstest
