[AG-TECH] Help with venue server
Andrew Rowley Andrew.Rowley at manchester.ac.uk
Fri Oct 15 03:52:30 CDT 2004
This sounds like a DNS problem.  I cannot find the IP address of
foqgro1.intra.ecu.edu.  Are you sure that this is registered in DNS?
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0615
Email: Andrew.Rowley at manchester.ac.uk
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Vandiford, William Matthew
Sent: 11 October 2004 15:46
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Help with venue server
I am cuurently in the process of trying to configure my own venue. I
have it set up, but I run into problem when I try to access my venue
from another machine. When I type in the URL of my venue
(https://foqgro1.intra.ecu.edu:8000/Venues/default) it gives me a Can
not enter venue message which states "Can not connect to venue located
at https://foqgro1.intra.ecu.edu:8000/Venues/default." This only happens
when I try to open up the venue from a separate machine. Any information
will be greatly appreciated.
Thanks, Matt
More information about the Kenstest mailing list
