[AG-TECH] RAT Problem
Ti Leggett leggett at mcs.anl.gov
Wed Oct 13 08:24:44 CDT 2004
You can try to sever the linein-lineout passthrough by doing something
like:
/usr/bin/amixer -c 0 cset numid=18,iface=MIXER,name='Line Playback
Switch' off
You might need to do a
/usr/bin/amixer controls
To find the exact numid for your card's 'Line Playback Switch'
I put this is in a shell script and run it once you've settled in the
venue as alsa/rat likes to revert the changes everytime it starts.
On Fri, 2004-10-08 at 11:55, Chris Rosenthal wrote:
> I have a weird problem with RAT.  My incoming bit rate drops to 0
> whenever my talk check box is not checked.  So, if talk is on, then it
> seems fine.  If talk is off, then I can’t be heard (obviously), but I
> also can’t hear anything (my incoming bit rate goes to 0 b/s).
> If anyone has seen this before and knows what it is, let me know.
> Thanks,
> Chris
> Chris Rosenthal
> Email: cmr at evl.uic.edu
> Phone: (312) 996-3002
> Electronic Visualization Laboratory
> University of Illinois - Chicago
More information about the Kenstest mailing list
