[AG-TECH] ALSA and RAT
Osland, CD (Chris) C.D.Osland at rl.ac.uk
Wed Oct 13 03:28:14 CDT 2004
Just a shot in the dark, as I don't know the driver, but it
could be that some aspect of the system is not full duplex,
as raising one level is affecting another.
Cheers
Chris
____________________________________________________________________
Chris Osland                                               Office tel: +44
(0) 1235 446565
Digital Media and Access Grid                          Medialab tel: +44 (0)
1235 446459
BIT Department                                     Access Grid room tel: +44
(0) 1235 445666
e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
(0) 1235 445597
CCLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Gavin W. Burris aka 86
> Sent: 12 October 2004 17:44
> To: Andrew Rowley
> Cc: 'Access Grid Technical mailing list'
> Subject: RE: [AG-TECH] ALSA and RAT
> The proper source is selected, line-in, and I am sending audio.  The
> problem is that the slider is not adjusting the record or capture
> level, but instead the volume of the immediate playback through
> line-out/speakers of what is being captured.  The slider gives me
> local reinforcement when I don't want it, instead of adjusting the
> capture level that ends up transmitting to the net.
> Andrew Rowley wrote (on Tue, 12 Oct 2004 at 16:27):
> > Hi,
> > Check what is displayed under "Talk" next to the arrow (>).
>  It should say
> > something like "Microphone" or "Line In".  Clicking on the
> arrow (>) cycles
> > through the various options.  Note that if you can hear
> audio, you may still
> > not be sending audio.  If the wrong item is selected by the
> arrow in rat,
> > you probably are not sending audio.
> > Andrew :)
> > Access Grid Support Centre,
> > RSS Group,
> > Manchester Computing,
> > Kilburn Building,
> > University of Manchester,
> > Oxford Road,
> > Manchester,
> > M13 9PL,
> > UK
> > Tel: +44(0)161-275 0615
> > Email: Andrew.Rowley at manchester.ac.uk
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
> > Sent: 08 October 2004 20:45
> > To: Access Grid Technical mailing list
> > Subject: [AG-TECH] ALSA and RAT
> > I've got my audio machine running Debain/GNU Linux and everything is
> > great.  I'm using the ALSA emu10k1 driver for a SoundBlaster Live!
> > card.
> > The only thing strange is that the slider in RAT for "Talk"
> adjusts the
> > volume locally recorded audio is played back through line-out to the
> > Gentner and speakers, not the actual capture level of
> line-in from the
> > Gentner and mics.  Is this a bug?
> > Cheers,
> > Senior Systems Programmer
> > Penn State Visualization Group
> > http://viz.aset.psu.edu/ga5in
More information about the Kenstest mailing list
