[AG-TECH] Re: Shared Applications Not Working after upgrading to AGToolkit 2.3
Susanne Lefvert lefvert at mcs.anl.gov
Tue Oct 12 12:45:24 CDT 2004
Hello Jason,
I am copying an old message thread to you that includes information on how to
solve this issue.   Also, I will forward this to the ag-tech list so other
people can take part of the solution as well.  Let me know if you have more
questions.
Susanne Lefvert
On Tuesday 12 October 2004 11:49 am, Jason Smith wrote:
> Hello,
>     I am Jason Smith from Howard University and I am
> working on getting the AG setup for SC2004 and ran
> into a few problems with the shared applications.  We
> just upgraded to AGTK2.3 from 2.2 today.  Cindy has
> forwarded us to you to try to get this working.  Thank
> you for your time.
> Jason Smith
------------------------ copied message ---------------------------------
> -----Original Message-----
> From: Susanne Lefvert <lefvert at mcs.anl.gov>
> To: "David McNabb" <mcnabb at umd.edu>
> Date: Mon, 4 Oct 2004 08:50:45 -0500
> Subject: Re: shared apps problem on AG2.3
> Hello David,
> Your shared applications do not work due to some old state left from
> previous installations, please try following:
> * Rename C:\Documents and Settings\Username\Application
> Data\AccessGrid\ApplicationDatabase
> Data\AccessGrid\Config\ApplicationDatabase
> Data\AccessGrid\SharedApplications
> Then restart the client and see if that works better.
> If you still are having problems you could try renaming the entire C:
> \Documents and Settings\Username\AccessGrid directory. Make sure you export
> your certificates before renaming, that way it is easy to import them again
> after starting the client.
> Let me know if this helps,
> Susanne
> On Friday 01 October 2004 02:34 pm, you wrote:
> > Hi Suzanne,
> > I wanted to report that I am unable to run the shared presentation or
> > shared browser tools on my AGN, though the shared question tool does
> > work. A second node on campus with identical hardware, also running 2.3
> > but installed on a new machine (never had older AGTk's on it) *is* able
> > to run all varieties of the shared apps.
> > I tried the trick of renaming the db file (though I noticed there were
> > two of these, one was one level higher in the folder tree than the one
> > mentioned in the hint) but this did not help.  Any suggestions?  Can I
> > send you any useful logs?
> > Thanks.
> >   --David McNabb
> > p.s. We need to use this node (no shared apps working yet) for SC Global.
More information about the Kenstest mailing list
