[AG-TECH] ALSA and RAT
Gavin W. Burris aka 86 ga5in at psu.edu
Tue Oct 12 11:43:56 CDT 2004
The proper source is selected, line-in, and I am sending audio.  The
problem is that the slider is not adjusting the record or capture
level, but instead the volume of the immediate playback through
line-out/speakers of what is being captured.  The slider gives me
local reinforcement when I don't want it, instead of adjusting the
capture level that ends up transmitting to the net.
Andrew Rowley wrote (on Tue, 12 Oct 2004 at 16:27):
> Hi,
> Check what is displayed under "Talk" next to the arrow (>).  It should say
> something like "Microphone" or "Line In".  Clicking on the arrow (>) cycles
> through the various options.  Note that if you can hear audio, you may still
> not be sending audio.  If the wrong item is selected by the arrow in rat,
> you probably are not sending audio.
> Andrew :)
> Access Grid Support Centre,
> RSS Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0615
> Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
> Of Gavin W. Burris aka 86
> Sent: 08 October 2004 20:45
> To: Access Grid Technical mailing list
> Subject: [AG-TECH] ALSA and RAT
> I've got my audio machine running Debain/GNU Linux and everything is
> great.  I'm using the ALSA emu10k1 driver for a SoundBlaster Live!
> card.
> The only thing strange is that the slider in RAT for "Talk" adjusts the
> volume locally recorded audio is played back through line-out to the
> Gentner and speakers, not the actual capture level of line-in from the
> Gentner and mics.  Is this a bug?
> Cheers,
> Senior Systems Programmer
> Penn State Visualization Group
> http://viz.aset.psu.edu/ga5in
More information about the Kenstest mailing list
