[AG-TECH] Crashing VIC in AG2.3
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Fri Oct 8 10:56:00 CDT 2004
I believe that the AG2 config starts vic transmitting. When you run vic
manually, transmit is not enabled by default. So it might be that you are
not getting an error because you are not transmitting anything. Also in
AG2, if you have a videoproducer and videoconsumer service, 2 vics will be
loaded, although only one of them will be able to transmit.
The saved versions of the services (uncompressed) should be in
C:\Documents and Settings\<username>\Application
Data\AccessGrid\local_services\<service>
where <username> is your windows username and <service> is the name of the
service you want the files for. You can also look in
VideoProducerService.py to see what is being configured.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0615
Email: Andrew.Rowley at manchester.ac.uk
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of David Wallom
Sent: 07 October 2004 16:07
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Crashing VIC in AG2.3
Hello,
I am having severe problems with VIC on my PIG system.
When I start up the system with Audio and Video services the Video service
instance of VIC crashes instantly with MS debug. I have seen this when using
AG 1 when it tries to startup two instance of VIC both trying to connect to
the same driver.
My query is this though. When I get vic out of the videoproducer zip files
and run it, it works fine. So what exactly does the configuration inbuilt in
AG2 do. Also where is the saved version of you service stored???
Regards
David
Dr. David Wallom
Operations Director
Centre for e-Research Bristol
Rm 4.56
H.H. Wills Physics Laboratory
Tyndall Avenue
Bristol
BS8 1TL
Tel +44 (0)117 928 8769
More information about the Kenstest
