[AG-TECH] Shared Presentation broken in 2.3? **URGENT**
Douglas Kosovic douglask at itee.uq.edu.au
Mon Oct 4 20:30:06 CDT 2004
Hi Randy,
> Has anyone had success with the Shared Presentation included with 2.3?
> This was broken for me in the betas, and I'm getting the same problem now.
> I'm going against a 2.3 venue server on FC2, with Doug's latest RPMs.  I'm
> fairly certain that I removed all the old information about the previous
> setup, but perhaps not.
> The symptom on the client side is that I cannot see the powerpoint file
> that I uploaded into the venue, nor can I upload a local file.
> As always happens - I've got a high level demo on Wednesday.
> Should I re-install the venue server from scratch?  I've already done that
> with the client.
I'll see if I can reproduce the problem with a Venue Server running on FC2
some time today.
One possible workaround in the mean time is to put the PowerPoint slides on
a webserver, then paste the URLs in the Shared Presentation control.
Known problems with the client-side Shared Presentation on FC2:
1. the master isn't able to turn pages in OpenOffice slide-show mode
    (press Esc and run OO in non-slideshow mode)
2.  may need to run "agpm.py --post-install" after updating from
AccessGrid-2.3-3.i386.rpm
    (this only happens with an update, but not with an erase followed by an
install)
Cheers,
Doug
More information about the Kenstest mailing list
