[AG-TECH] Re: Building of VIC under Gentoo Fails
Ti Leggett leggett at mcs.anl.gov
Mon Oct 4 10:46:01 CDT 2004
I just installed xorg-X11 on a test machine at the lab, and then
recompiled vic against and it worked perfectly. It seems there's some
incompatibility on your machine with glibc. It will take further
investigating to find out exactly why....
On Sat, 2004-09-25 at 12:23, West Suhanic wrote:
> Hello All:
> As per the documentation I issued the following command:
> emerge -aq ag-libs/agtk
> Everything goes along nicely until vic.  The building of vic under
> Gentoo-(Linux 2.6.7 r11) fails.
> It fails with the following message.
> : warning: Using 'getservbyname' in statically linked applications requires
> at runtime the shared libraries from the glibc version used for linking
> /usr/X11R6/lib/libX11.a(XlibInt.o)(.text+0x818): In function
> `_XEventsQueued':
> : undefined reference to `pthread_equal'
> /usr/X11R6/lib/libX11.a(XlibInt.o)(.text+0xb91): In function
> `_XEventsQueued':
> /usr/X11R6/lib/libX11.a(XlibInt.o)(.text+0xbae): In function
> `_XEventsQueued':
> /usr/X11R6/lib/libX11.a(XlibInt.o)(.text+0xbcd): In function
> `_XEventsQueued':
> /usr/X11R6/lib/libX11.a(XlibInt.o)(.text+0xbe8): In function
> `_XEventsQueued':
> /usr/X11R6/lib/libX11.a(XlibInt.o)(.text+0xc64): more undefined references
> to `pthread_equal' follow
> collect2: ld returned 1 exit status
> make: *** [vic] Error 1
> Any suggestions? Yes I have gnome installed.
> thank you,
> West Suhanic.
More information about the Kenstest mailing list
