[AG-TECH] fedora core 2 running AG2.3 using hauppauge wintv
Douglas Kosovic douglask at itee.uq.edu.au
Mon Oct 4 01:54:16 CDT 2004
Hi Zeppy,
> anybody here got same problem using hauppauge wintv in fedora core 2 for
> access grid 2.3, when i try to transmit the access grid 2.3 will freeze.
> does anybody here had experience like what i experience using with
> hauppauge wintv card. thanks.
What freezes? The Venue Client or vic?
Are you using a Hauppauge WinTV card based on the Conexant 2388x chip family
(cx88 driver) or the Bt878 (bttv driver)? If you are using the bttv driver
and are transmitting at 25fps, try changing it to 24fps.
Doug
More information about the Kenstest mailing list
