[AG-TECH] RE Access Grid Hardware, expensive
Michael daley
Mike.W.Daley at cs.cardiff.ac.uk
Fri Oct 1 07:49:44 CDT 2004
Hi Marie-Noelle
Here is a run down of machines that we currently use with configurations.
Cardiffs configurations with AG2.3 software.
We have been running a number of different configurations. As perminent
nodes
Our main grid node is the standard 4 machine configuration.
Our display machine has 6 video heads
(One Quadra 4 head PCI card and 1 Matrox G450 dual head). On a dual
Pentium III 1Gig processors.
Never had a problem with this. Running under XP. With a 1 Gig Ethernet Card
The video capture has 4 Hauppage Capture cards (Original spec) running
under Fedora again Dual P3 1Gig. With 100 M Ethercard
The Audio machine is standard SoundBlaster card (Orig spec) P3 1 gig
running under XP. 100 M Ethercard
We also have a lecture theatre set up as a PIG (Done this summer)which is
1 PC running Fedora P4 3 gig. 3 Osprey capture cards. SoundBlaster audio
card and Dual head Matrox G550
We also have a PIG P4 3gig PC with USB Logitech camera and built in
sound card.
Another node is a desktop node
P4 2.8 gig with 3 monitors attached to a Matrox Parhelia Card. Video via
Logitech USB camera and. SoundBlaster Audio card
We have several laptop PIG configurations for members of staff.
In addition we have a "Mobile Grid" Which consists of two machines.
Video capture and display is done on a Dual Xeon processor, Osprey
Capture Cards and Matrox G200 4 Head Video Card
Audio capture on a P4 2.8 Gig Proc. with SoundBlaster Card
The Mobile grid is taken to various exhibitions around Wales. We have
successfully demonstrated the Access Grid over Satallite links at 1 gig.
and even used Viz Server at the same time (Bit slow though would not
suggest it).
Not sure if this is any use.
All the best
Mike
More information about the Kenstest
