[AG-TECH] Access grid Hardware , expensive !
Marie-Noelle Dauphin
dauphin at idris.fr
Fri Oct 1 04:03:20 CDT 2004
hello ,
We used to Access grid on a single machine node (PIG on windows XP ) with agtk
2.1 ....
Now we are thinking that perhaps Two or three PC will be better ...
with atk 2.3 because when there is more than 6 participants with vic , it's difficult to move the vic windows ..
I read the "tutorial : how to build an install an access grid node " .
I have two questions :
why do they recommand 4 pc : Display windows 2000 ,video linux, audio
linux, control windows XP and not for example
4 pc (control,display,vido,audio) all with linux
or 4 pc (control,display,vido,audio)all with windows XP .....
because linux better for video capture and audio ? I don't understand ..
Does the tutorial "how to build an install an access grid node" is up
to date with atk 2.3 .....
For example with fedora core 2 do you still recommend Hauppauge video
capture and Creative Ensoniq Audio pci ?
computing equipment + media equipment + projection equipment is too
much expensive ...... hum hum !! :-(
at first time , Is it possible to used only 2 pc ? audio+control on
1pc with an only audio card ? and video+display on another pc with an
only video capture card ? wich with windows ? wich with fedora ?
does atk 2.3 run with only 2 pc ?
thank's for your response !!!!
best regards
Marie-Noëlle
More information about the Kenstest
