[AG-TECH] Ospreys & FC2
Doug Bowman bowman at mvoice.com
Wed Aug 25 10:48:01 CDT 2004
Mediavoice is using the same config on Asus motherboards. We tend to
stick with the Hauppauge capture cards as we've never had a problem with
them, although I continue to search for a quad capture card that is
trouble free and has four S-Vid ins.
The latest room config Mediavoice built uses a Colorgraphics Xentra GT4
Quad display but we had to go to the PCI version to get acceptable
performance out of the card. All four outputs on this card are OpenGL
compliant which is important in the visualization work in which this
group is engaged.
Doug Bowman
Director
Mediavoice Communications Inc.
http://www.mvoice.com
http://www.accessgrid.ca
Osland, CD (Chris) wrote:
>We use the same with 2x2.8 GHz Xeons, 1 Gb memory, 2x40 Gb disks,
>Matrox Parhelia display card (one output to console, two to
>AG displays) although we hope to move to QID card, onboard
>audio (amazingly - no problems) interfaced through standard
>balanced-unbalanced convertor, Winnov Videum 4400 VO.
>Cheers
>Chris
>____________________________________________________________________
>Chris Osland                                               Office tel: +44
>(0) 1235 446565
>Digital Media and Access Grid                          Medialab tel: +44 (0)
>1235 446459
>BIT Department                                     Access Grid room tel: +44
>(0) 1235 445666
>e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
>(0) 1235 445597
>CCLRC Rutherford Appleton Laboratory (Bldg. R18)
>Chilton, DIDCOT, Oxon OX11 0QX, UK
>[The contents of this email are confidential and are for the use of the
>intended recipient only.
>If you are not the intended recipient do not take any action on it or show
>it to anyone else,
>but return this email to the sender and delete your copy of it.]
>>-----Original Message-----
>>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
>>Behalf Of George Estes
>>Sent: 20 August 2004 17:22
>>To: ag-tech at mcs.anl.gov
>>Subject: RE: [AG-TECH] Ospreys & FC2
>>Don,
>>   We use a rack mount case with the PC-DL Asus motherboard
>>(5 PCI slots)
>>for all three(now two) machines, linux and WXP.  So far this
>>motherboard
>>has worked great for us.  A local retailer builds the machines for us.
>>George
>>At 10:44 AM 8/20/2004, you wrote:
>>>Thank you for that information Stuart.
>>>  We are planning to purchase new computers and video capture to
>>>replace our aging AG1.x system. In several posts on this Tech
>>>group I have asked if there is a known to work hardware
>>>solution. While I don't nind a challenge it took us almost
>>>two years getting Dell to write newer BIOS before the 4 Hauppage
>>>cards would work together. We had to abandon Dell for our
>>>Display computer. So we wound up with more expenditure than
>>>should have been required.
>>>   Please anyone chime in and contribute their recommendations
>>>for a full AG2.x functioning system. We don't require a turnkey
>>>solution.
>>>Thanks,
>>>Don Lewis
>>>Little Rock, Arkansas
>>>Behalf Of Stuart Poulton
>>>Sent: Friday, August 20, 2004 7:49 AM
>>>To: Robert Callaway
>>>Cc: ag-tech at mcs.anl.gov
>>>Subject: Re: [AG-TECH] Ospreys & FC2
>>>Dear All,
>>>I'm pleased to report that I finally have 4 working osprey
>>cards under
>>>FC2.....
>>>I still have to manually change the input to s-video for each card on
>>>changing venues, I've not tried to resolve this yet.
>>>I'm hoping to carry out tests on Monday, probably starting around 9am
>>>GMT if anyone is around please let me know your assistance will be
>>>greatly appreciated.
>>>Regards
>>>Stuart
URL: <http://lists.mcs.anl.gov/pipermail/kenstest/attachments/20040825/a1790416/attachment.htm>
Name: D:\My Documents\mvoice\coa.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/kenstest/attachments/20040825/a1790416/attachment.jpg>
More information about the Kenstest mailing list
