[AG-TECH] CVS AGTk client cannot connect to default server (RH9.0)
Thomas D. Uram turam at mcs.anl.gov
Fri Aug 20 13:14:54 CDT 2004
Socrates:
That file is created during the last step of the source install process:
% source $GLOBUS_LOCATION/etc/globus-user-env.csh
% $GPT_LOCATION/sbin/gpt-postinstall
Have you done this step, and you still don't have the file?
Tom
Socrates Varakliotis wrote:
> Thomas' comment regarding the LANG env variable took me a step further.
> gpt installed fine after unsetting it on RH9.
> Then, the Globus toolkit v.2.4.3 got installed fine.
> The next step was to re-install pyGlobus (swig has been installed
> already). Now, here's another problem:
> [root at Gorilla pyGlobus]# python2.3 setup.py install --run-swig
> Checking for which modules to build
> Checking the util module
> Missing dependency to build the util package.
> This package is required to build all of pyGlobus.
> The following is the error message from globus-makefile-header.
> ('ERROR: Cannot open
> /usr/local/globus/libexec/globus-sh-tools-vars.sh!\n',)
> Now exiting from the build.
> Looking inside /usr/local/globus/libexec I can't find the file
> globus-sh-tools-vars.sh, which is required by the installer script. Here
> is what exists in this directory:
> globus-args-parser-header
> globus-bootstrap.sh
> globus-build-env-gcc32dbgpthr.sh
> globus-is-local-user
> globus-libc-hostname
> globus-sh-tools.sh
> gpt-bootstrap.sh
> Any more comments? Is this a version problem again?
> Socrates.
>>> The paragraph on Linux says:
>>> 1. Have Globus 2.4.3 installed, instructions for that are elsewhere.
>>> (you only *need* the globus-data-management-client bundle)
>>> Where exactly are the instructions you mention? And where is globus
>>> 2.4.3?
>>> AFAIK, the latest stable globus release is 3.2.1.
>> I finally managed to locate globus 2.4.3 under globus' download
>> archives (a well-hidden link): http://www.globus.org/gt2.4/download.html
>> Now, I have the following problem: The gpt-3.0.1 won't install,
>> dumping the following error:
>> [ucacsva at Gorilla gpt-3.0.1]$ ./build_gpt --prefix=$GPT_LOCATION
>> build_gpt ====> installing GPT into /usr/local/globus
>> build_gpt ====> building support/Compress-Zlib-1.16
>> build_gpt ====> building support/Archive-Tar-0.22
>> build_gpt ====> building support/PodParser-1.18
>> build_gpt ====> building support/Digest-MD5-2.20
>> Makefile:75: *** missing separator.  Stop.
>> ERROR: the following command failed: make >/dev/null
>> Any ideas please?
>> Regards,
>> Socrates.
More information about the Kenstest mailing list
