[AG-TECH] problems with new 2.2 PIG and service manager
Jim Miller
millerjw at psc.edu
Thu Aug 19 12:44:08 CDT 2004
We have a new fresh PIG install of the AG2.2 toolkit, and when I try to
set the node URL, i get an error that the URL is invalid. Bringing up
the venue client in debug mode, it errors with an 'Invalid Service
Manager URL. Below is the output. Currently the attached debug output
states https://localhost:11000/ServiceManager but origionally had the
machine IP as the URL which outputs the same error.
Below is a snip from the debug window. Can someone help?
Jim
08/19/04 08:51:46 3796 NodeService agnodeservice.py:393 INFO Trying
to load
node configuration from: C:\Documents and
Settings\GHOOD.PSC\Application Data\A
ccessGrid\Config\nodeConfig\defaultWindows
08/19/04 08:51:46 3796 NodeService agnodeservice.py:466 INFO
AddServiceMana
ger: Invalid service manager url (https://localhost:11000/ServiceManager)
08/19/04 08:51:46 3796 NodeService agnodeservice.py:367 ERROR
Exception load
ing default configuration.
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py",
line 365, in
LoadDefaultConfig
self.LoadConfiguration( self.defaultConfig )
line 500, in
LoadConfiguration
raise Exception(exceptionText)
Exception: Couldn't reach service manager: localhost:11000
08/19/04 08:51:46 3796 VenueClient venueclient.py:317 ERROR Error
loading de
fault configuration
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line
315, in _
_StartWebService
self.ns.LoadDefaultConfig()
line 369, in
LoadDefaultConfig
self.defaultConfig)
Exception: ('Failed to load default configuration <%s>', 'defaultWindows')
08/19/04 08:51:46 3796 VenueClient venueclient.py:190 DEBUG
__createPersonal
DataStore: Creating personal datastore at C:\Documents and
plication Data\AccessGrid\Config\personalDataStore using prefix
personalDataStor
e and port 0
More information about the Kenstest
