[AG-TECH] CVS AGTk client cannot connect to default server (RH9.0)
Socrates Varakliotis S.Varakliotis at cs.ucl.ac.uk
Thu Aug 19 15:15:25 CDT 2004
Socrates Varakliotis wrote:
> The paragraph on Linux says:
> 1. Have Globus 2.4.3 installed, instructions for that are elsewhere.
> (you only *need* the globus-data-management-client bundle)
> Where exactly are the instructions you mention? And where is globus 2.4.3?
> AFAIK, the latest stable globus release is 3.2.1.
I finally managed to locate globus 2.4.3 under globus' download archives
(a well-hidden link): http://www.globus.org/gt2.4/download.html
Now, I have the following problem: The gpt-3.0.1 won't install, dumping
the following error:
[ucacsva at Gorilla gpt-3.0.1]$ ./build_gpt --prefix=$GPT_LOCATION
build_gpt ====> installing GPT into /usr/local/globus
build_gpt ====> building support/Compress-Zlib-1.16
build_gpt ====> building support/Archive-Tar-0.22
build_gpt ====> building support/PodParser-1.18
build_gpt ====> building support/Digest-MD5-2.20
Makefile:75: *** missing separator.  Stop.
ERROR: the following command failed: make >/dev/null
Any ideas please?
Socrates.
Dr. Socrates Varakliotis
UCL Computer Science
Gower Street, WC1E 6BT, London, UK
Tel: +44 20 7679 3696
Fax: +44 20 7387 1397
More information about the Kenstest mailing list
