[AG-TECH] AG 2.3 and Service Manager
Monika Rabarison monika.k.rabarison at ccaix.jsums.edu
Thu Aug 19 10:56:49 CDT 2004
Sorry Jen, I missed to mention that port change.
Cheers,
Monika
On Thu, 19 Aug 2004, Jennifer Hare wrote:
> Ahhh... I see.  Thanks!
> -----Original Message-----
> From: Thomas D. Uram [mailto:turam at mcs.anl.gov]
> Sent: Thursday, August 19, 2004 11:21 AM
> To: Jennifer Hare
> Cc: 'Monika Rabarison'; ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] AG 2.3 and Service Manager
> Jennifer:
> The service manager is still started by the venue client; as of 2.2, the
> service manager is started on the same port as the node service, port
> 11000.  If you rebuild your node configuration using the service manager
> on port 11000, and save this new config as your default, everything
> should work automatically as it did before, the way you describe.
> The problem you're encountering occurs because you're using an old node
> configuration that assumes a service manager on port 12000 which is, as
> you mentioned, not running.
> Tom
> > I can add those services, but the problem is that when I run the venue
> > client and go to "Manage my node", there is no service manager running.  I
> > need to manually start the service manager each time, add it (in the
> "Manage
> > my node" dialog) and then I can add those services.
> > With my 2.1.2 pig install, this was all automatic, I could run the venue
> > client and it would automatically start the service manager and add those
> > services.  I never had to start the service manager manually or add the
> > audio/video services manually.  Instead, this all seemed to get setup
> during
> > installation.
> > So, did I just miss some configuration wizard during the installation of
> > 2.3?  Or have things changed?
> > Thanks!
> > Jen
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf
> > Of Monika Rabarison
> > Sent: Wednesday, August 18, 2004 5:48 PM
> > To: Jennifer Hare
> > Cc: ag-tech at mcs.anl.gov
> > Jen,
> > Have you added AudioService and VideoService within
> > "Manage my node"?
> > Monika
> > On Wed, 18 Aug 2004, Jennifer Hare wrote:
> >>I just installed AG 2.3 beta on my Win XP desktop (for a PIG node).  When
> > I
> >>run the Venue Client, and enter a venue, the vic and rat don't start.
> > When
> >>I checked to see what was going on, I discovered that the service manager
> >>doesn't automatically start when you run the venue client.  Is this
> > normal?
> >>Or did I mess something up?  With AG 2.1.2, didn't the service manager
> > start
> >>automatically when you ran the venue client?
> >>Thanks,
> >>Jen
> > Monika Rabarison
> > Systems Administrator
> > Information Technology/HPCVI
> > Jackson State University
> > Office:(601)979-5933
> > SciVis Lab:(601)979-1061
> > JSUvisNode:(601)979-1056
> > JSUeNode:(601)979-1081
Monika Rabarison
More information about the Kenstest mailing list
