[AG-TECH] Add Video Producer Help
Thomas D. Uram
turam at mcs.anl.gov
Wed Aug 18 16:49:29 CDT 2004
That could indicate that the windows machine is not reachable from the
rh box; this could be because the GLOBUS_HOSTNAME is not set correctly,
or the WinXP firewall is on. If you look in ~/.AccessGrid/agsm.log on
the rh machine, there might be more of an indication what went wrong.
If it's not evident, you can send the file to me and I'll take a look.
Tom
Chris Rosenthal wrote:
> Does anyone know what the following means?
> Exception: Error adding service: Exception: AGServiceManager.AddService
> failed: Unknown reason
> Right now, I wanted to try a two machine setup on 2.1.2. The RedHat 7.3
> machine will do the video capture as it has done for a long time and the
> new WinXP machine will handle the rest. I was able to add the video
> capture machine as a service manager, but when I went to add a video
> producer service, it threw the above exception. Anyone know where or
> why this is thrown?
> Thanks,
> Chris
> Chris Rosenthal
> Phone: (312) 996-3002
> Email: cmr at evl.uic.edu
> Electronic Visualization Laboratory
> University of Illinois - Chicago
More information about the Kenstest
