[AG-TECH] CVS AGTk client cannot connect to default server (RH9.0)
Socrates Varakliotis S.Varakliotis at cs.ucl.ac.uk
Wed Aug 18 10:26:00 CDT 2004
Dear All:
I installed the cvs version of the AGTk on RH9.0.
I also requested and was issued with a valid certificate, which I
imported successfully. After launching the Venu Client with:
prompt> python2.3 AccessGrid/bin/VenueClient.py --debug
I cannot connect to the default venue at ANL. The output on the screen
follows. The client's log file is also attached.
Any help appreciated.
Best Regards,
Dr. Socrates Varakliotis
UCL Computer Science
Gower Street, WC1E 6BT, London, UK
Tel: +44 20 7679 3696
Fax: +44 20 7387 1397
[root at Gorilla agtk-cvs]# python AccessGrid/bin/VenueClient.py --debug &
[1] 7568
[root at Gorilla agtk-cvs]# 18/08/04 16:14:11 1074896032 Toolkit
Toolkit.py:121 INFO  Logfile Name: VenueClient.log
18/08/04 16:14:10 1074896032 ProxyGen     ProxyGen.py:567 DEBUG Using
GT24 proxy code
18/08/04 16:14:11 1074896032 Toolkit     Toolkit.py:79 DEBUG
Initializing AG Toolkit version 2.3
18/08/04 16:14:11 1074896032 Platform     Config.py:1050 INFO  gnome
directory /root/.gnome/application-info or /root/.gnome/mime-info not
found, not registering file type .agpkg with gnome
found, not registering file type .vv2d with gnome
18/08/04 16:14:11 1074896032 Toolkit     Toolkit.py:121 INFO  Logfile
18/08/04 16:14:11 1074896032 Platform     Config.py:341 DEBUG retrieved
local IP address 128.16.66.76
18/08/04 16:14:11 1074896032 CertificateManager
CertificateManager.py:263 DEBUG Opened repository
/root/.AccessGrid/Config/certRepo
CertificateManager.py:729 DEBUG Configuring standard environment
CertificateManager.py:797 DEBUG Using default identity /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2
CertificateManager.py:868 DEBUG Initializing environment with proxy cert
for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates
Varakliotis2
CertificateManager.py:887 DEBUG Configuring for user proxy issued from
Varakliotis2
CertificateManager.py:890 DEBUG Proxy /tmp/x509up_u0 will expire
18/08/04 20:27:23
18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:293 DEBUG
__StartWebService: venueclient: https://128.16.66.76:64182/VenueClient
18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:191 DEBUG
__createPersonalDataStore: Creating personal datastore at
/root/.AccessGrid/Config/personalDataStore using prefix
personalDataStore and port 0
18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1512 DEBUG
Creating thread 0
18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1517 DEBUG
Starting thread 0
18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1519 DEBUG
Waiting thread 0
18/08/04 16:14:11 1142135600 DataStore     DataStore.py:1525 DEBUG
Worker 0 starting
18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1522 DEBUG Done
creating workers
18/08/04 16:14:11 1074896032 DataStore     DataStore.py:270 DEBUG
Reading persisted data from:
/root/.AccessGrid/Config/personalDataStore/DataStore.dat
18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:216 DEBUG
__createPersonalDataStore: Load personal data from file
18/08/04 16:14:11 1074896032 VenueClientController
VenueClientController.py:1343 DEBUG There is no personal venues file to
load.
18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:802 DEBUG
EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
18/08/04 16:14:18 1074896032 CertificateManager
CertificateManager.py:633 DEBUG HaveValidProxy: found proxy ident
Varakliotis2/CN=proxy
18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:825 INFO
EnterVenue: Error getting node capabilities
18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:700 DEBUG
EnterVenue: Invoke venue enter
18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:667 ERROR
SOAP fault occurred
Traceback (most recent call last):
   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line
347, in __call
     config = self.config)
187, in call
     r.endheaders()
   File "/usr/local/lib/python2.3/httplib.py", line 712, in endheaders
     self._send_output()
   File "/usr/local/lib/python2.3/httplib.py", line 597, in _send_output
     self.send(msg)
   File "/usr/local/lib/python2.3/httplib.py", line 564, in send
     self.connect()
   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line
1425, in connect
     self.sock.connect(self.host, self.port, self.io_attr)
988, in connect
     raise ex
GSITCPSocketException: globus_xio_gsi: gss_init_sec_context failed.
18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:846 ERROR
EnterVenue: globus tcp exception: ('globus_xio_gsi: gss_init_sec_context
failed.',)
18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:853 ERROR
EnterVenue: failed
   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/VenueClient.py",
line 829, in EnterVenue
     self.__EnterVenue(URL)
line 701, in __EnterVenue
     (venueState, self.privateId, self.streamDescList ) =
self.__venueProxy.Enter( self.profile )
   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/Venue.py", line
3339, in Enter
     (r1, r2, r3) = self.proxy.Enter(profile)
453, in __call__
     return self.__r_call(*args, **kw)
475, in __r_call
     self.__hd, self.__ma)
347, in __call
187, in call
     r.endheaders()
     self._send_output()
     self.send(msg)
     self.connect()
1425, in connect
988, in connect
     raise ex
18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2054 DEBUG
bin.VenueClient::EnterVenue: Enter venue with url:
18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2067 DEBUG
warningString:
18/08/04 16:14:28 1074896032 VenueClient     VenueClientUI.py:1701 INFO
  --------- END VenueClient
18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1530 DEBUG
Worker 0 gets cmd quit
18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1543 DEBUG
Worker 0 exiting
18/08/04 16:14:28 1150528304 DataStore     DataStore.py:1603 ERROR
Exception handling request
   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/DataStore.py",
line 1599, in thread_run
     self.handle_request()
   File "/usr/local/lib/python2.3/SocketServer.py", line 217, in
handle_request
     request, client_address = self.get_request()
843, in get_request
     raise(str(self.socket) + str(" is having trouble listening!:" +
str(ex.args)))
<pyGlobus.io.GSITCPSocket instance at 0x41de94ec> is having trouble
listening!:('an I/O operation was cancelled',)
18/08/04 16:14:28 1133742896 Hosting     Server.py:65 ERROR Exception in
SOAP server main loop
   File
"/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/hosting/SOAPpy/Server.py",
line 63, in Run
     self._server.handle_request()
handle_request
   File "/usr/local/lib/python2.3/site-packages/SOAPpy/GSIServer.py",
line 140, in get_request
     sock, addr = ThreadingGSITCPSocketServer.get_request(self)
843, in get_request
str(ex.args)))
<pyGlobus.io.GSITCPSocket instance at 0x41de908c> is having trouble
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/kenstest/attachments/20040818/a4de6704/attachment.diff>
More information about the Kenstest mailing list
