[AG-TECH] 2.2 video problems.
Victor M. Babson, Jr.
vbabson at secsg.uga.edu
Fri Aug 13 12:08:58 CDT 2004
Okay,
So I had this linux box with 2.1.2 working just fine.
Now that I have removed 2.1.2 and installed 2.2 I can't seem to get any video feed working. I installed xawtv (wasn't installed for 2.1.2 -- but v4l2 was).
VenueClient runs and connects okay. In fact everything seems to run just fine, but I can't seem to get any video feed except for x11 which is working okay. I have a spectra 8 card:
04:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Unknown device aa04:1464
Flags: bus master, medium devsel, latency 32, IRQ 24
Memory at fcbff000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
04:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at fcbfe000 (32-bit, prefetchable) [size=4K]
04:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Unknown device aa05:1465
Flags: bus master, medium devsel, latency 32, IRQ 25
Memory at fcbfd000 (32-bit, prefetchable) [size=4K]
04:09.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at fcbfc000 (32-bit, prefetchable) [size=4K]
04:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Unknown device aa06:1466
Flags: bus master, medium devsel, latency 32, IRQ 26
Memory at fcbfb000 (32-bit, prefetchable) [size=4K]
04:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at fcbfa000 (32-bit, prefetchable) [size=4K]
04:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Unknown device aa07:1467
Flags: bus master, medium devsel, latency 32, IRQ 27
Memory at fcbf9000 (32-bit, prefetchable) [size=4K]
04:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at fcbf8000 (32-bit, prefetchable) [size=4K]
When running a prog like xcam, I can see my video feed just fine. When I try using xawtv, however, I get a blank screen. I've tried xawtv 3.54 to 3.93.
I've seen some posts that say I should edit the videopath in /usr/lib/python2.2/site-packages/AccessGrid/Platform/unix/Config.py to point to /dev instead of /proc/video/dev. I've done this, but it just makes the x11 feed disappear.
Tom!! Help!! I'd like to get 2.2 going.
--Vic
P.S. -- You don't have to be Tom if you can offer some help! :)
Project Coordinator
Management Info. Specialist
University of Georgia
Biochemistry & Mol. Biology
B203 Life Science Bldg.
Athens, GA 30602
(706) 542-6565
URL: <http://lists.mcs.anl.gov/pipermail/kenstest/attachments/20040813/24e678f2/attachment.htm>
More information about the Kenstest
