[AG-TECH] AG2.2 - Venue Client
Anne M. Hammond hammond at solarz.Colorado.EDU
Wed Aug 11 13:04:08 CDT 2004
Thanks Michael.
Start Service Manager from menu
Start Node Service from menu
  INFO Trying to load node configuration from
  C:\Documents and Settings\Anne Hammond\Application Data\AccessGrid\ \
    Config\nodeConfig\defaultWindows
  <Fault SOAP-ENV ....
  ERROR Exception adding service AudioService.zip
I think I am going to uninstall 2.2, mv the AccessGrid file aside in order
to retain the certificates, and then reinstall 2.2.
Anne
>From: "Michael Braitmaier" <braitmaier at hlrs.de>
>To: "Anne M. Hammond" <hammond at solarz.Colorado.EDU>, <ag-tech at mcs.anl.gov>
>Cc: <hammond at solarz.Colorado.EDU>
>Subject: Re: [AG-TECH] AG2.2 - Venue Client
>Date: Wed, 11 Aug 2004 08:05:13 +0200
>MIME-Version: 1.0
>Content-Transfer-Encoding: 7bit
>X-Priority: 3
>X-MSMail-Priority: Normal
>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.2180
>X-Spam-Checker-Version: SpamAssassin 2.63 (2004-01-11) on lcd.colorado.edu
>X-Spam-Level:
>X-Spam-Status: No, hits=0.0 required=5.0 tests=none autolearn=no version=2.63
>X-Keywords:
>I guess you have to start the ServiceManager.py and NodeService.py first,
>then start VenueClient.py. The VenueClient should then load the default
>configuration.
>At least this was an issue on my system.
>Michael
>Michael Braitmaier
>HLRS - Visualization / Video Conferencing
>University of Stuttgart
>Germany
>Website: http://www.hlrs.de/organization/vis/people/braitmaier/
>----- Original Message -----
>From: "Anne M. Hammond" <hammond at lcd.Colorado.EDU>
>To: <ag-tech at mcs.anl.gov>
>Cc: <hammond at lcd.Colorado.EDU>
>Sent: Tuesday, August 10, 2004 11:04 PM
>Subject: [AG-TECH] AG2.2 - Venue Client
>>I had installed AG2.2, after installing ActiveState Active Python 2.3
>> and wxPython 2.4 for Python 2.3.
>> I am using an IBM ThinkPad with a Logitech camera (which works).
>> When I bring up the Venue Client, the Rat and Vic thumbnails do not
>> come up.  Audio and Video are enabled.
>> I tried twice to start the Node Setup Wizard.  It gets 80% into
>> the green startup bar, and then gives a messages that it cannot
>> start the Wizard.
>> I have run the Venue Client in debug mode.  The first ERROR is
>> venueclient.py:317 ERROR Error loading default configuration.
>> Is there a way to troubleshoot this, or do I need to fall back to
>> AG2.1?  If I need to fall back, do I need to get the older versions
>> of Active Python and wxPython??
>> Thanks in advance.
>> Anne Hammond
>> University of Colorado at Boulder
More information about the Kenstest mailing list
