[AG-TECH] AG2.2 - Venue Client
Michael Braitmaier
braitmaier at hlrs.de
Wed Aug 11 01:05:13 CDT 2004
I guess you have to start the ServiceManager.py and NodeService.py first,
then start VenueClient.py. The VenueClient should then load the default
configuration.
At least this was an issue on my system.
Michael
Michael Braitmaier
HLRS - Visualization / Video Conferencing
University of Stuttgart
Germany
Website: http://www.hlrs.de/organization/vis/people/braitmaier/
----- Original Message -----
From: "Anne M. Hammond" <hammond at lcd.Colorado.EDU>
To: <ag-tech at mcs.anl.gov>
Cc: <hammond at lcd.Colorado.EDU>
Sent: Tuesday, August 10, 2004 11:04 PM
Subject: [AG-TECH] AG2.2 - Venue Client
>I had installed AG2.2, after installing ActiveState Active Python 2.3
> and wxPython 2.4 for Python 2.3.
> I am using an IBM ThinkPad with a Logitech camera (which works).
> When I bring up the Venue Client, the Rat and Vic thumbnails do not
> come up. Audio and Video are enabled.
> I tried twice to start the Node Setup Wizard. It gets 80% into
> the green startup bar, and then gives a messages that it cannot
> start the Wizard.
> I have run the Venue Client in debug mode. The first ERROR is
> venueclient.py:317 ERROR Error loading default configuration.
> Is there a way to troubleshoot this, or do I need to fall back to
> AG2.1? If I need to fall back, do I need to get the older versions
> of Active Python and wxPython??
> Thanks in advance.
> Anne Hammond
> University of Colorado at Boulder
More information about the Kenstest
