[AG-TECH] Which version should I use?
Natalia Costas Lago
natalia at cesga.es
Tue Aug 10 07:51:44 CDT 2004
Hi Doug,
Maybe you mean the final??
.. is the AGTK 2.3 rpm file located under
:http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/stable/RPMS for Fedora Core
2??. I am confused as I thought that 2.3 beta release hadnt been migrated
yet. I followed the ag document to install AGTK 2.2
(http://www.accessgrid.org/agdp/howto/fedora2install/1.0/book1.html), that
was released yesterday, but there are no instructions for AGTK 2.3, only for
AGTK 2.2. So, my question is:
- Where can I download AGTK 2.3 beta for FC2? Is that URL indicated below?
and
- Should I follow the same procedure to install it as I did with AGTK 2.2?
Should i use the same version for wxpython (in the documentation the author
indicated some problems compiling wxpython 2.5)?
Natalia.
----- Original Message -----
From: "Douglas Kosovic" <douglask at itee.uq.edu.au>
To: <ag-tech at mcs.anl.gov>
Sent: Tuesday, August 10, 2004 2:01 PM
Subject: Re: [AG-TECH] Which version should I use?
> Hi Natalia,
> > Thank you very much for your answer, i was wondering when will be AGTK
2.3
> > migrated to FC2?.
> Most likely the day after the AGTk 2.3 source code is released or has been
> CVS tagged, I will make a set of AGTk RPMs for FC1 and another set for
FC2.
> They will be found where the AGTk 2.3 beta1 RPMs are currently located:
> http://www.itee.uq.edu.au/~agn/ag_fedora/FC1/stable/
> > > After the Fedora AGTk 2.3 RPMs are released, there may not be any
> > > future RPMs made for FC1 (which uses python 2.2.3), as python 2.3 is
> > > now being used on the 3 ANL supported platforms. FC2 is safe, as it
> > > comes with python 2.3.3.
> Cheers,
> Doug
More information about the Kenstest
