[AG-TECH] bootable live cd iso avalaible to download [CMM #1690]
Joseph joseph at cs.usyd.edu.au
Tue Aug 10 01:56:13 CDT 2004
Hi
I'm pleased to see AG on a knoppix might help you. However, I just would
like to warn you about a possible trouble : this bootable live cd *should*
be working with all pc, but it's not 100% sure. It may be necessary to
test it before on each kind of pc and sometimes may required some tricks
(mainly based on the use of cheatcodes generally, which is quite easy, but
still...).
Apart from this, the access of people with Anonymous certificate is just a
question of configuration of the AG Node server. In your case Chris seems
to agree to change it, so it shouldn't be a trouble anymore.
Cheers,
     Joseph
On Tue, 10 Aug 2004 16:11:56 +1000, Christoph Willing
<willing at itee.uq.edu.au> wrote:
> On Tue, 2004-08-10 at 15:40, Duncan Waddell wrote:
>> However the Certificate provided with the Knoppix CD does not allow me
>> to connect to the Asia-Pacific Access Grid Venue Server.  If I import my
>> own certificate from floppy disk I can enter happily enough but I am now
>> thinking of 40 schools and should they use the existing CD I would have
>> to relay CyberSTEM via a non-local venue server.  (i.e. they could only
>> currently see us if we served via the USA ANL venue server)
> Duncan,
> This is an issue with the APAG server not accepting anonymous
> certificates. I'm working on fixing this, sooner rather than later.
> chris
More information about the Kenstest mailing list
