[AG-TECH] AGTk 2.3 BETA Released
Thomas D. Uram
turam at mcs.anl.gov
Mon Aug 9 18:19:26 CDT 2004
You didn't jump the gun. This looks like a credential (or
credential-handling) problem. You should file this as a bug, and
include your VenueServer.log file to help us determine what happened
during credential init.
Fred Dech wrote:
> i jumped the gun. i guess that the [--configfile=CONFIGFILE] arguement is
> now required. when i add that, to the command line everything's fine.
> --fred
> On Mon, Aug 09, 2004 at 05:04PM, Fred Dech said:
>>hi Doug.
>>i just noticed this when i started up the venue server:
>>sucag1(fdech)13% /usr/bin/python2 /usr/bin/VenueServer.py
>>bound to port 8000
>>bound to port 8006
>>Traceback (most recent call last):
>> File "/usr/bin/VenueServer.py", line 127, in ?
>> main()
>> File "/usr/bin/VenueServer.py", line 89, in main
>> venueServer = VenueServer(server, app.GetOption('configfilename'))
>> File "/usr/bin/VenueServer.py", line 273, in __init__
>> File "/usr/bin/VenueServer.py", line 461, in LoadPersistentVenues
>> File "/usr/bin/VenueServer.py", line 729, in AddVenue
>> File "/sandbox/agtk/dist-20040809_102253/lib/python2.3/site-packages/AccessGrid/Venue.py", line 379, in __init__
>> File "/sandbox/agtk/dist-20040809_102253/lib/python2.3/site-packages/AccessGrid/Security/Role.py", line 195, in AddSubject
>>AccessGrid.Security.Subject.InvalidSubject
>>i thought it might be an imcompatibility with earlier .cfg and .dat files,
>>but i removed them and still got the same messages.
>>--fred
>>On Mon, Aug 09, 2004 at 05:55PM, Douglas Kosovic said:
>>>The Fedora Core 1 & 2 AGTk 2.3 beta1 RPMs can be found at:
>>> http://www.itee.uq.edu.au/~agn/ag_fedora/
>>>If you were previous using yum with the AGTk CVS snaphots, then you will
>>>need to modify:
>>> /etc/yum.conf
>>>Similarily for rhn-applet and up2date, the following file will need to be
>>>modifed:
>>> /etc/sysconfig/rhn/sources
>>>The modifications involve changing instance of 'unstable' to 'stable'.
>>>The unstable folders will continue to contain AGTk CVS snapshots.
>>>Doug
More information about the Kenstest
