[AG-TECH] Osprey-100 and WinXP Access Grid Toolkit 2.2
Fred Dech fdech at uchicago.edu
Thu Aug 5 11:11:49 CDT 2004
cool!  thanks, Michael.  i'll have to set that on the systems that are
still repeatedly asking for it.  some have stopped..?  'great help,
especially now that i've got one arm in a sling.
--fred
On Thu, Aug 05, 2004 at 10:11AM, Michael Miller said:
> Fred,
> I figured out the solution and am posting it to the email list so I can
> find it later.  To stop vic from asking for the rtpName and rtpEmail put
> this in the registry:
> HKEY_LOCAL_MACHINE\SOFTWARE\vic\vic\rtpName="..."
> HKEY_LOCAL_MACHINE\SOFTWARE\vic\vic\rtpEmail="..."
> With the ... replaced with the appropriate values.  It appears this is not
> necessary on all machines.  I think it has something to do with whether you
> install as the Administrator or not.
> HTH
> Michael Miller
> NCSA
> At 10:13 AM 6/23/2004, Fred Dech wrote:
> >... i also then need to re-submit my VIC rtpEmail info,
> >not once, not twice, but three times.  ouch.  this is not usable at this
> >point.
> >--fred
> >On Wed, Jun 23, 2004 at 09:37AM, Chris Rosenthal said:
> >> Yes.  I know that that's available.  That's a real pain to have to do
> >each
> >> time you change venues, though.  Also, I kept getting errors when doing
> >it
> >> that way.  So, I just dropped back to 2.1.2 and everything seems good in
> >> that respect.
> >> Maybe 2.2.1 will take care of this.
> >> Chris
> >> Chris Rosenthal                               cmr at evl.uic.edu
> >> Electronic Visualization Lab                  (312) 996-3002
> >> University of Illinois at Chicago
> >> On Tue, 22 Jun 2004, Fred Dech wrote:
> >> > i just stumbled through this.
> >> > WinXP.  add your VideoProducerService for each capture card, then
> >you'll have
> >> > some blank 1 Real Vic and 1 or more blank Vics.  for each blank Vic,
> >select
> >> > 'Menu' at the bottom, and the 'Devices' drop-down should display all
> >of your
> >> > Ospreys.  select a different one for each Vic.
> >> > hope that helps.
> >> > --fred
> >> > On Tue, Jun 22, 2004 at 09:03AM, Duncan Waddell said:
> >> > > Hi learned folks,
> >> > > Add my name to the list too.  I also have an urgent need to get an
> >> > > Osprey-100 card working with AGT 2.2 (WinXP).
> >> > > Duncan
> >> > > A Quay wrote:
> >> > > >I have the exact same problem. In a week I have to visit a college
> >in
> >> > > >Miami to install an AG node and really need help on getting four
> >Osprey
> >> > > >100???s working on a WinXP box.
> >> > > >Andy Quay
> >> > > >Associate Director
> >> > > >Digital Worlds Institute, University of Florida
> >> > > >-----Original Message-----
> >> > > >*From:* Chris Rosenthal [mailto:cmr at evl.uic.edu]
> >> > > >*Sent:* Friday, June 18, 2004 3:11 PM
> >> > > >*To:* ag-tech at mcs.anl.gov
> >> > > >*Subject:* [AG-TECH] Video Producer Config Help
> >> > > >Hello,
> >> > > >I know there???s been a lot of talk about configuring video capture
> >> > > >devices in Linux.  I???ve got four Osprey 100???s on a WinXP node
> >and the
> >> > > >Video Producer Services always default to the same capture card on
> >AGT
> >> > > >2.2.  There doesn???t seem to be the same options for configuring
> >the
> >> > > >sources from the node management dialog (as previous versions).  Am
> >I
> >> > > >supposed to enter something in the port text box?  Is there a
> >patch out
> >> > > >or coming out soon that makes this easier?
> >> > > >I will really appreciate your help in taking care of this problem.
> >> > > Duncan Waddell  (BSc)
> >> > > Principal Scientific Officer
> >> > > Centre for Microscopy and Microanalysis
> >> > > The University of Queensland.   St. Lucia.  Qld.  4072
> >> > > Telephone:      +61-7-3365-4216
> >> > > Facsimile:      +61-7-3365-1775
> >> > > WWW:            http://www.uq.edu.au/nanoworld/nanohome.html
> >> > >        Any opinion expressed is that of the writer,
> >> > >    and not necessarily that of CMM or of the University.
> >> >   University of Chicago Dept. of Surgery
> >> >   Ph: (773) 834-8359, Fax: (773) 834-8140
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve everything
> desired, and usually deliver everything you could have hoped for and even
> more." -Paul Debevec
More information about the Kenstest mailing list
