[AG-TECH] SetData (was: AGTk questions)
Dioselin Gonzalez
dioselin at purdue.edu
Wed Aug 4 17:36:41 CDT 2004
Hello Tom,
Thanks for the info. However, I still have problems with setting data
other than strings. I'm just doing this:
tdata = 123
sharedAppClient.SetData("dataname",tdata)
It raises an exception when tdata is of a type other than string. Below
is the log from different tests, first with tdata=123, then tdata=[123]
and finally tdata="123".
08/04/04 17:18:46 2724 Toolkit toolkit.py:79 DEBUG Initializing AG
Toolkit version 2.2
08/04/04 17:18:48 2724 EventClient eventclient.py:166 DEBUG Have
callback handle _685ee500_p_callbackStruct
08/04/04 17:18:52 2724 Tests sharedappclient.py:222 ERROR
SharedAppClient.SetData: Failed to set data, key: dataname, value: 123
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\SharedAppClient.py",
line 218, in SetData
self.__appProxy.SetData(self.__privateId, dataKey, dataValue)
File
"C:\software\AccessGrid\build\dist-20040601_225453\Lib\site-packages\AccessGrid\SharedApplication.py",
line 565, in SetData
File
"C:\software\AccessGrid\build\dist-20040601_225453\Lib\site-packages\SOAPpy\Client.py",
line 453, in __call__
File
line 475, in __r_call
File
line 389, in __call
faultType: <Fault SOAP-ENV:Server: Method Failed:
Venues:default:apps:000000fe2be22977008400f600820021ee7:SetData>
08/04/04 17:20:57 3196 Toolkit toolkit.py:79 DEBUG Initializing AG
Toolkit version 2.2
08/04/04 17:20:58 3196 EventClient eventclient.py:166 DEBUG Have
callback handle _5854e500_p_callbackStruct
08/04/04 17:21:02 3196 Tests sharedappclient.py:222 ERROR
SharedAppClient.SetData: Failed to set data, key: dataname, value: [123]
File
File
File
File
line 389, in __call
Venues:default:apps:000000fe2be426ca008400f600820021670:SetData>
08/04/04 17:22:22 2456 Toolkit toolkit.py:79 DEBUG Initializing AG
Toolkit version 2.2
08/04/04 17:22:23 2456 EventClient eventclient.py:166 DEBUG Have
08/04/04 17:22:28 2444 EventClient eventclient.py:183 DEBUG Got read
handle=_7894e300_p_globus_io_handle_t result=(0, None, None) n=4
08/04/04 17:22:28 2444 EventClient eventclient.py:236 DEBUG Freeing
callback _5854e500_p_callbackStruct within callback
08/04/04 17:22:28 2444 EventClient eventclient.py:245 DEBUG Have new
handle=_7894e300_p_globus_io_handle_t result=(0, None, None) n=310
08/04/04 17:22:28 2444 EventClient eventclient.py:225 DEBUG finally
read enough data, wait=310 buflen=310
08/04/04 17:22:28 2444 EventClient eventclient.py:260 DEBUG Invoking
callback <bound method SharedAppClient.HandleEvent of
<AccessGrid.SharedAppClient.SharedAppClient instance at 0x01285C38>>...
08/04/04 17:22:28 2444 EventClient eventclient.py:266 DEBUG Invoking
<AccessGrid.SharedAppClient.SharedAppClient instance at 0x01285C38>>...done
08/04/04 17:22:28 2444 EventClient eventclient.py:268 INFO No
callback for Set application data!
08/04/04 17:22:28 2444 EventClient eventclient.py:327 INFO Got
callback for Set application data event!
08/04/04 17:22:28 2444 EventClient eventclient.py:231 DEBUG
handleData returns
08/04/04 17:22:28 2456 Tests test.py:65 DEBUG got data: '123'
08/04/04 17:22:28 2456 Tests test.py:66 DEBUG end
Thomas D. Uram wrote:
> Dioselin Gonzalez wrote:
>> Hello, I'm writing shared applications and have a few questions, I
>> apologize in advance if they sound crazy :)
>> 1. Can we store data of type other than string in the venue? Like
>> integers, lists, etc. I see 'sharedAppClient.SetData("dataname",
>> 123)' raises an exception because the data value is not string.
> You should be able to set (almost) any type of data you want. I just
> tried with ints, lists, and dicts and did not get an exception. Could
> you send more info?
More information about the Kenstest
