[AG-TECH] Connection failure, RH9 linux probs
Jerome
jeremy.knope at gmail.com
Wed Aug 4 16:02:50 CDT 2004
thanks, that did it
On Wed, 04 Aug 2004 14:28:28 -0500, Thomas D. Uram <turam at mcs.anl.gov> wrote:
> Jerome:
> We're using globus 2.4.3, which is also labeled as the "Pre-WS bundle"
> on the globus software pages, and the corresponding pyGlobus. Since the
> error message references xio, it looks like you're using some later code
> (which one?). Anyway, you should have more success using the 2.4.3
> versions.
> Tom
> Jerome wrote:
> > I build AGToolkit from source, following directions on a website I
> > found, used latest cvs of AG itself
> > problem is everything went ok, except now when I try to connect to the
> > venuserver it fails and traces back to some failure in globus it looks
> > like but no clue how to go about resolving the issue
> > the faliure:
> > 08/04/2004 11:25:16 AM 1074896512 VenueClient VenueClient.py:700 DEBUG Enter
> > Venue: Invoke venue enter
> > 08/04/2004 11:25:21 AM 1074896512 VenueClient VenueClient.py:667 ERROR SOAP
> > fault occurred
> > Traceback (most recent call last):
> > File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 347, in _
> > _call
> > config = self.config)
> > File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 187, in c
> > all
> > r.endheaders()
> > File "/usr/local/lib/python2.3/httplib.py", line 712, in endheaders
> > self._send_output()
> > File "/usr/local/lib/python2.3/httplib.py", line 597, in _send_output
> > self.send(msg)
> > File "/usr/local/lib/python2.3/httplib.py", line 564, in send
> > self.connect()
> > File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 1434, in co
> > nnect
> > self.sock.connect(self.host, self.port, self.io_attr)
> > File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 991, in con
> > nect
> > raise ex
> > GSITCPSocketException: globus_xio_gsi: gss_init_sec_context failed.
> > any help is greatly appreciated, i built from source because i get way
> > more frustrated trying to get rpms to work. i was able to do it fine
> > on OS X so was more than comfortable to try on our RH9 linux machine.
> > thanks
> > --jerome
More information about the Kenstest
