[AG-TECH] Mac OS X Progress, RAT is being stuborn
Jerome jeremy.knope at gmail.com
Mon Aug 2 16:56:20 CDT 2004
yeah i just recently got the OS X open mash build, the vic as a viewer
seems to work except when i join the lobby and then it quits with too
many files error after trying to load all of the streams
haven't really tried vat much beyond it opening for the lobby
i'm interesting in checking into possibly rebuilding it against OS X
Tcl/Tk if i can get the source with the os x changes.
 --jerome
On Mon, 2 Aug 2004 22:03:20 +0100, grzesiek at mi2.hr <grzesiek at mi2.hr> wrote:
> Hi,
> Have a look on www.openmash.org.
> OpenMash is already running on osx however its using vat for audio (less codecs and different sampling frequencies)
> Grzesiek
> On Sun, Aug 01, 2004 at 08:25:30PM -0400, Jerome wrote:
> > So I managed to treck thru hacking at VIC to compile under OS X
> > 10.3.4, wasn't bad just header files with different paths...
> > haven't found much on OS X AG stuff besides hearing that there's a beta...
> > but i've been working on installing the various components for AGTk
> > 2.2, Globus, PyGlobus, and other modules are all installed, but I'm
> > stuck at one thing that keeps me from continuing to explore...
> > gcc -g -O2 -W -Wall -Wbad-function-cast -Wmissing-prototypes
> > channel.o channel_types.o cc_vanilla.o cc_rdncy.o cc_layered.o
> > render_3D.o repair.o  ts.o playout.o net.o source.o session.o
> > main_engine.o mbus_engine.o audio.o cushion.o mix.o parameters.o
> > transmit.o playout_calc.o ui_send_rtp.o ui_send_audio.o
> > ui_send_prefs.o ui_send_stats.o transcoder.o rtp_dump.o rtp_callback.o
> > settings.o pdb.o pktbuf.o tonegen.o voxlet.o fatal_error.o
> > libuclaudio.a libuclcodec.a libuclsndfile.a
> > -L/Users/jerome/PythonProjects/AccessGrid/ag-media/common/src
> > -luclmmbase  -lm  -o rat-4.2.22-media
> > ld: Undefined symbols:
> > _rtp_get_ssrc_count
> > it looks to me this symbol is defined in the UCL MM library,
> > ../common/src/libuclmmbase.a
> > but attempting to try various other methods to linking it still ends
> > up with undefined symbol
> > anybody got suggestions? much appreciated
More information about the Kenstest mailing list
