Trying to Get Started in Missoula
Bill Nickless nickless at mcs.anl.gov
Mon Sep 25 14:51:08 CDT 2000
-----BEGIN PGP SIGNED MESSAGE-----
At 05:31 PM 9/22/2000 -0600, Don Morton wrote:
>1) Get a beacon server up and running here.  Our campus
>network now has Internet 2, and I'm told that we "could"
>get multicast enabled.  I've browsed through the AG and
>Beacon websites, and I see nothing to suggest that I
>can't get away with the following for a test setup:
>- 100MHz Pentium running Slackware 7.1 (though can change to RedHat if
>necessary)
>- Standard 3com 3c??? 10/100 ethernet card
>- multicast provided to me via 10BaseT network
>Is this realistic?  I feel "somewhat" confident of
>this first step...
This is quite enough performance to run a beacon.  The only thing the
beacon really needs is a Java 1.2 runtime, and I have every confidence that
Slackware should be able to provide that.
For the beacon multicast group, 10BaseT should be sufficient.  That will
let you get the IP multicast routing protocols operating and
tested.  However, you should be planning to upgrade that to 100Base
Ethernet before doing your first real Access Grid participation.
In terms of IP multicast deployment, please feel free to put me in contact
with your campus networking people.  I would be pleased to assist to
whatever level I can, up to and including traveling to your campus to help.
Bill Nickless    http://www.mcs.anl.gov/people/nickless      +1 630 252 7390
PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7     nickless at mcs.anl.gov
-----BEGIN PGP SIGNATURE-----
Version: PGPfreeware 6.5.8 for non-commercial use <http://www.pgp.com>
iQCVAwUBOc+sq6wgm7ipJDXBAQEFyAP/SKzeewsKyFUw/FQ2XO/JMlscdpWXtV4Y
EJfTJKWGvWgvJo+DtV0Hg01zld4f625+FEwNSh0PrTqEGInFFJSWvIey/us0QoOs
dKWsDPI9ByNvNiap6DduBFm67TZRrOMPM11lsnd7pSmY3Lo5Kxoak6Qn4mHNk/su
L1bD1KM/X/U=
=uYr0
-----END PGP SIGNATURE-----
More information about the Kenstest mailing list
