itaps-parallel One particularly difficult thing in one of the use cases...
Mark Shephard
shephard at scorec.rpi.edu
Wed Jun 2 04:37:47 CDT 2010
Thanks Carl for the explanation. I was thinking pretty much the same
things as you, but was not sure how to state it.
Carl Ollivier-Gooch wrote:
> On 10-06-01 08:52 PM, Tim Tautges wrote:
>> Hi all,
>> Here, I attempt to describe one of the particularly difficult parts of
>> one of the use cases. I think this at least exposes a potential problem
>> in the currently specified iMeshP; I think it also demonstrates the
>> problem with entities always having to be in parts, but that's more of a
>> subjective statement.
>> The use case is radiation transport. In a nutshell, consider processes
>> arranged in a 2d array, with each column representing an angle, and each
>> row a subdomain in the spatial partition. The spatial partition of the
>> mesh will be distributed across all processes in a column; a given
>> spatial subdomain is copied onto each process in a row.
> Oh, now I understand (at least sort of) what's going on with this case...
>> Initializing the mesh onto this processor arrangement is done in 3 steps:
>> 1. load the mesh onto the 1st column, in a domain-decomposed fashion
>> typical of other DD-based codes
>> 2. share the mesh from the 1st column across a row of processes
>> 3. establish sharing relations in the other columns
>> It's in step 3 that I see the problem. Here, the mesh for a spatial
>> subdomain is already represented in the iMesh Instance on each process,
>> but the Partition representing the column hasn't been created yet. After
>> you create that Partition, and a Part in that Partition, you need to
>> assign the mesh from the Part in the row-based Partition into that Part
>> in the column-based Partition. How do you do that? The function
>> iMeshP_exchEntArrToPartsAll is a collective call, and implies that
>> you're moving entities from one Part to another. But, the entities we're
>> talking about here aren't part of any Part in that column Partition. I'd
>> prefer to use iMesh_addEntToSet, but I'm guessing that would break other
>> implementations.
> In fact, as I read it, the spec says specifically that iMesh_addEntToSet
> gets used here, with a part handle passed as the set. This is no
> different, as I see it, from any other situation in which you're
> creating a partition rather than reading one. And yes, it's true that
> in the transition of setting up this (or any similar) partition, there's
> necessarily a limbo period in which entities haven't yet been assigned
> to parts. IMO, this is different than creating entities with no part
> assignment and leaving them in that state.
> This is a common enough scenario that I'm sure FMDB and Simmetrix have
> ways of handling this, even though new entities created once a partition
> is established are created in a part. (For the GRUMMP implementation
> that's on the drawing board, there's no problem here, either.)
> My issue with the whole "entities must belong to a part" thing is a
> consistency argument. I expect that, if we don't require all entities
> to be in parts, at least at the end of parallel services, some
> subsequent parallel operations will not be properly defined. I don't
> see that outcome as reasonable. Consider:
> Premise 1 (written in the spec): An entity -must- have an owner if
> it's going to be modified. (Ownership == right to modify)
> Premise 2: It's never safe for a service to assume that no other
> service will ever modify the mesh after it's done, nor that other
> services (whether or not they modify the mesh) can tolerate partless
> entities, even if they can be identified as such. (Ghosting patterns
> could change, for instance, making it so that entities that weren't
> ghosted now are, and need an owner for that reason.)
> If those two premises hold up (and I obviously think they do), any
> parallel service that wants to work and play well with others needs to
> assign all entities to parts before completion. Yes, I think this even
> applies to the parallel meshing scenario we discussed in the telecon:
> the parallel version of this must, IMO, at the very least post-process
> the mesh that the parallel-unaware mesher produced to get stuff into
> parts. This would be a wrapper, not a mod to the mesher itself.
> As an aside, if an entity isn't explicitly assigned to a part, what
> should a function like getEntOwnerPart return? And does it pass the
> giggle test for this to -not- return the one part on a process when
> there is only one? And if unowned parts get an inferred value in this
> function, how does one do that in the presence of multiple parts per
> process and still avoid giggling?
> From a (planned) implementation point of view, I don't think I'm really
> going to care whether entities are assigned to the right part initially,
> assigned to an arbitrary part and moved later, or not assigned to a part
> initially and assigned later. These should all be cheap in time (O(1)
> with a small constant) and space (no more than an int per entity).
>> This example also demonstrates the need either for another function, to
>> negotiate shared entities between Parts, or to expand the definition of
>> iMeshP_createGhostEntsAll to include the functionality (the latter would
>> be most natural for MOAB, since the same function is used in MOAB's
>> parallel stuff to do either; I distinguish by allowing the # layers
>> specified to be zero, in which case you're requesting the resolution of
>> shared entities at an interface).
> I agree this functionality is needed when any mesh is partitioned
> instead of being read in parallel.
> Carl
More information about the itaps-parallel
