itaps-parallel Modification to use case #3
Tim Tautges tautges at mcs.anl.gov
Fri May 14 16:37:05 CDT 2010
Hi all,
   I went back to the Plimpton et. al paper describing their parallel contact algorithm, to make sure I was describing
it correctly, and what do you know, I wasn't.  I've revised the use case description to better match their approach to
the problem.  I also listed the reference used.
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/itaps-parallel/attachments/20100514/f6108635/attachment.txt>
More information about the itaps-parallel mailing list
