itaps-parallel Notes from today's meeting
Mark Beall
mbeall at simmetrix.com
Mon Apr 19 10:11:24 CDT 2010
On Apr 19, 2010, at 10:06 AM, tautges at mcs.anl.gov wrote:
>> Eventually, in the hyperparallel world that's coming, apps and
>> implementations may both have to be written to be multithreaded
>> shared-memory processes within a node (OpenMP?) with communication
>> between nodes (MPI?). This isn't in conflict with the notion of
>> exactly one part (and iMesh instance) per process; it just requires
>> more careful programming of apps/services that use the interface.
> Imeshp is written in terms of message passing anyway, so it'll need
> to change to handle threads anyway.
It depends on how you want to approach using threads. Our
implementation (of our partitioned mesh, mesh generation, mesh
improvement and mesh adaptivity) use either MPI parallel or multiple
threads and the abstraction is the same. There are some good and bad
points to this (although nothing about it precludes using threads in a
different way in addition). In theory, we could use this for MPI
parallel with multiple threads per process, however we've never done
that due to lack of a thread-safe MPI implementation (not sure if
there is one these days - we could work around the lack of it with
additional effort) and lack of a reason to do it.
mark
More information about the itaps-parallel
