itaps-parallel Notes from today's meeting
tautges at mcs.anl.gov tautges at mcs.anl.gov
Mon Apr 19 09:13:36 CDT 2010
That sounds really hard, but ok.
- tim
On Apr 19, 2010, at 8:55 AM, Mark Shephard <shephard at scorec.rpi.edu>
wrote:
> Tim,
> I am sure that we can effectively implement contact, including the
> evolution of contact and inclusion of mesh adaptation if desired as
> I have indicated (a single partition of the mesh). The issue of
> needing to migrate things between parts during adaptation has
> nothing to do with it. Some form of dynamic load balancing is to
> account for any change (contact evolution or mesh adaptation) if one
> wants to continue to scale. Again, that is independent of the other
> questions.
> Mark
> tautges at mcs.anl.gov wrote:
>> I'm not sure this is true. If I understand your amr method
>> correctly, you only adapt the interior of meshes, migrating a
>> potion of an interface to make that so.  Or, have you changed
>> that?  Whereas with parallel contact (at least as implemented by
>> sandia, which I'm familiar with), the face partition is completely
>> unrelated to the region partition.
>> - tim
>> On Apr 19, 2010, at 5:15 AM, Mark Shephard
>> <shephard at scorec.rpi.edu> wrote:
>>> Two quick comments/questions:
>>> Is there a conference call today, Monday? If yes, what time?
>>> The issues of doing a contact problem in parallel are really much
>>> the say as doing mesh adaptivity in parallel with a form of
>>> nonmanifold model. The only new item past that of a 2-manifold
>>> situation is keeping  track of the contact face interactions.
>>> There is absolutely no problem doing this within in the concept of
>>> a single partition of the mesh. On the other hand, considering how
>>> to track an evolving contact interface through the use of multiple
>>> partitions of the mesh would actually add substantial complexity
>>> to the mesh up-date and dynamic load balancing processes.
>>> Mark
>>> Carl Ollivier-Gooch wrote:
>>>> Tim Tautges wrote:
>>>>> I think Jason's argument is important here: the easy things
>>>>> should be easy, and more complicated things possible.  I think
>>>>> this is related to Seegyoung's point about having a single API.
>>>>> I think what this boils down to is an assertion that we should
>>>>> think primarily in terms of one iMesh Instance per process.  For
>>>>> those applications wanting to use multiple instances, that
>>>>> implies communication between the instances at least
>>>>> conceptually, if not in the implementation also.  What this
>>>>> boils down to even further is that Part and iMesh instance are
>>>>> synonymous.  The issue of an entity assigned to exactly one Part
>>>>> morphs to one of representation vs. ownership: an entity can be
>>>>> represented in more than one instance (e.g. faces on part
>>>>> boundaries, in an element-based partition), but can be owned by
>>>>> only one of those instances.
>>>> Personally, I'm very much in favor of the part = instance
>>>> interpretation, for reasons already outlined.
>>>> In addition, I can easily see how we'll be able to implement
>>>> this, whereas with multiple parts per instance, the easiest
>>>> approach would be for us, effectively, to have multiple of our
>>>> current instances inside a wrapper; yuck!
>>>> At a higher level, this also makes the whole parts-as-special-
>>>> sets argument moot, saving us from possibly re-visiting that.  If
>>>> this is the way we decide to go, we'll want to do an audit of
>>>> iMeshP functions, because part handles will now be synonymous
>>>> with iMesh instance handles.  I suspect that a whole lot of
>>>> functions either go away or get simpler.  This is not a bad thing.
>>>>> One of the reasons we initially thought in terms of multiple
>>>>> parts per process was to handle over-partitionings, where a
>>>>> process could be assigned multiple parts, e.g. for better load
>>>>> balancing, and flexibility in what's stored with a mesh or how
>>>>> it's stored.  I think that concept is an artifact of how a
>>>>> partitioning is stored with the mesh (or how the mesh is stored
>>>>> in files to reflect a partitioning).  From an application's
>>>>> point of view, in most cases it's still going to want to access
>>>>> the mesh from a single instance on a given process, no matter
>>>>> how that mesh was loaded initially.  That's also how the mesh
>>>>> looks from most applications' points of view.  The use case of
>>>>> multiple parts, with shared interface entities duplicated, is
>>>>> mostly handled by having separate entities in the database, with
>>>>> special relations between them implying that they're the same.
>>>> I can see ways around the over-partitioning problem, though.
>>>> Most obviously, simply have multiple threads per processor, so
>>>> that the number of processes still matches the number of parts.
>>>> Or an app or implementation (or even the interface) could specify
>>>> how to merge parts to get the right number at run time, as Tim
>>>> hints at.
>>>> Eventually, in the hyperparallel world that's coming, apps and
>>>> implementations may both have to be written to be multithreaded
>>>> shared-memory processes within a node (OpenMP?) with
>>>> communication between nodes (MPI?).  This isn't in conflict with
>>>> the notion of exactly one part (and iMesh instance) per process;
>>>> it just requires more careful programming of apps/services that
>>>> use the interface.
>>>>> One of the complications that arises from having one instance
>>>>> per process (and one part per instance) is how do you
>>>>> repartition, or partition in serial.  I think that concept is
>>>>> handled by the notion of initializing a given parallel mesh
>>>>> either a) from a collection of collections, or a partition of
>>>>> parts, stored with and loaded with the mesh, or b) communication
>>>>> from one instance to another, using parallel migration of
>>>>> entities.  Of course, a) is easily handled using sets, if you
>>>>> have them; if you don't, it's just as easily handled using
>>>>> multiple files.  It also naturally handles establishing a
>>>>> parallel mesh based on one of several
>>>>> "partitionings" (collection of collections) stored with a mesh,
>>>>> e.g. using the geometric volumes, material types, or true
>>>>> partitions (generated by a partitioner).
>>>> This is a problem we always had, though, didn't we?  I mean, with
>>>> multiple instances per process, repartitioning to use a new
>>>> instance would require copying the whole mesh, including
>>>> adjacency, sets, tags, etc.  Do-able, but non-trivial, especially
>>>> (say) tags with entity handle value.
>>>> I don't have any conceptual issues in principle with the notion
>>>> of multiple partitionings of the same entities.  How an
>>>> implementation (or app) chooses to store the inactive partition
>>>> is obviously going to be implementation-dependent (sets vs tags
>>>> vs classification vs ???).  This potentially makes it tricky to
>>>> define an API for switching between them.
>>>> Also, what about the different, more subtle case where we -need-
>>>> two partitions active at once?  One use case is a contact
>>>> problem, where the 3D mesh and 2D surface are partitioned
>>>> separately (I'm assuming this is done, to get better load
>>>> balance?).  If you're also doing mesh adaptation as you go
>>>> (likely), now those 2D faces on the interface have owners in the
>>>> 3D partition (okay, some implementation don't represent them
>>>> explicitly, but it's safe to say that a face interior to a part
>>>> is going to be owned by that part...).  I see two alternatives.
>>>> 1. The easiest way to handle this in the current interfaces, as
>>>> far as parallel stuff goes, is to have two separate meshes (a 3D
>>>> mesh and a 2D manifold mesh), with tags or iRel (or something
>>>> similar) keeping the respective entities associated with each
>>>> other.  This implies two iMesh instances per process, one each
>>>> for the 3D and 2D manifold meshes, which isn't in conflict with
>>>> other stuff in this thread.
>>>> 2. You could also have two partitions active within a single
>>>> instance. I'm not quite sure how this would look, even
>>>> conceptually.  You'd have the full 3D mesh for the (3D) part,
>>>> plus a bunch of extra faces (and verts, at least) for the bits of
>>>> the 2D manifold mesh that isn't already resident.  The problem
>>>> with this is that you've got to strictly segregate things so that
>>>> iteration over (say) faces gets you what you wanted.  Yes, I
>>>> know, sets will do this, but it seems cumbersome...
>>>> I can't say I'm crazy about either of these alternatives, nor am
>>>> I invested in either one.  Hopefully, someone can come up with
>>>> something better.  For what's it's worth, I think this problem is
>>>> reasonably (completely?) independent of whether in "normal"
>>>> single mesh contexts we require exactly one part and iMesh
>>>> instance per process.
>>>> Having said that, I'll almost certainly be missing tomorrow's
>>>> telecon. I will, of course, be happy to kibitz afterwards by
>>>> email. :-)
>>>> Carl
More information about the itaps-parallel mailing list
