itaps-parallel Notes from today's meeting
Carl Ollivier-Gooch cfog at mech.ubc.ca
Sun Apr 18 15:07:47 CDT 2010
Tim Tautges wrote:
> I think Jason's argument is important here: the easy things should be
> easy, and more complicated things possible.  I think this is related to
> Seegyoung's point about having a single API.  I think what this boils
> down to is an assertion that we should think primarily in terms of one
> iMesh Instance per process.  For those applications wanting to use
> multiple instances, that implies communication between the instances at
> least conceptually, if not in the implementation also.  What this boils
> down to even further is that Part and iMesh instance are synonymous.
> The issue of an entity assigned to exactly one Part morphs to one of
> representation vs. ownership: an entity can be represented in more than
> one instance (e.g. faces on part boundaries, in an element-based
> partition), but can be owned by only one of those instances.
Personally, I'm very much in favor of the part = instance
interpretation, for reasons already outlined.
In addition, I can easily see how we'll be able to implement this,
whereas with multiple parts per instance, the easiest approach would be
for us, effectively, to have multiple of our current instances inside a
wrapper; yuck!
At a higher level, this also makes the whole parts-as-special-sets
argument moot, saving us from possibly re-visiting that.  If this is the
way we decide to go, we'll want to do an audit of iMeshP functions,
because part handles will now be synonymous with iMesh instance handles.
  I suspect that a whole lot of functions either go away or get simpler.
  This is not a bad thing.
> One of the reasons we initially thought in terms of multiple parts per
> process was to handle over-partitionings, where a process could be
> assigned multiple parts, e.g. for better load balancing, and flexibility
> in what's stored with a mesh or how it's stored.  I think that concept
> is an artifact of how a partitioning is stored with the mesh (or how the
> mesh is stored in files to reflect a partitioning).  From an
> application's point of view, in most cases it's still going to want to
> access the mesh from a single instance on a given process, no matter how
> that mesh was loaded initially.  That's also how the mesh looks from
> most applications' points of view.  The use case of multiple parts, with
> shared interface entities duplicated, is mostly handled by having
> separate entities in the database, with special relations between them
> implying that they're the same.
I can see ways around the over-partitioning problem, though.  Most
obviously, simply have multiple threads per processor, so that the
number of processes still matches the number of parts.  Or an app or
implementation (or even the interface) could specify how to merge parts
to get the right number at run time, as Tim hints at.
Eventually, in the hyperparallel world that's coming, apps and
implementations may both have to be written to be multithreaded
shared-memory processes within a node (OpenMP?) with communication
between nodes (MPI?).  This isn't in conflict with the notion of exactly
one part (and iMesh instance) per process; it just requires more careful
programming of apps/services that use the interface.
> One of the complications that arises from having one instance per
> process (and one part per instance) is how do you repartition, or
> partition in serial.  I think that concept is handled by the notion of
> initializing a given parallel mesh either a) from a collection of
> collections, or a partition of parts, stored with and loaded with the
> mesh, or b) communication from one instance to another, using parallel
> migration of entities.  Of course, a) is easily handled using sets, if
> you have them; if you don't, it's just as easily handled using multiple
> files.  It also naturally handles establishing a parallel mesh based on
> one of several "partitionings" (collection of collections) stored with a
> mesh, e.g. using the geometric volumes, material types, or true
> partitions (generated by a partitioner).
This is a problem we always had, though, didn't we?  I mean, with
multiple instances per process, repartitioning to use a new instance
would require copying the whole mesh, including adjacency, sets, tags,
etc.  Do-able, but non-trivial, especially (say) tags with entity handle
value.
I don't have any conceptual issues in principle with the notion of
multiple partitionings of the same entities.  How an implementation (or
app) chooses to store the inactive partition is obviously going to be
implementation-dependent (sets vs tags vs classification vs ???).  This
potentially makes it tricky to define an API for switching between them.
Also, what about the different, more subtle case where we -need- two
partitions active at once?  One use case is a contact problem, where the
3D mesh and 2D surface are partitioned separately (I'm assuming this is
done, to get better load balance?).  If you're also doing mesh
adaptation as you go (likely), now those 2D faces on the interface have
owners in the 3D partition (okay, some implementation don't represent
them explicitly, but it's safe to say that a face interior to a part is
going to be owned by that part...).  I see two alternatives.
1. The easiest way to handle this in the current interfaces, as far as
parallel stuff goes, is to have two separate meshes (a 3D mesh and a 2D
manifold mesh), with tags or iRel (or something similar) keeping the
respective entities associated with each other.  This implies two iMesh
instances per process, one each for the 3D and 2D manifold meshes, which
isn't in conflict with other stuff in this thread.
2. You could also have two partitions active within a single instance.
I'm not quite sure how this would look, even conceptually.  You'd have
the full 3D mesh for the (3D) part, plus a bunch of extra faces (and
verts, at least) for the bits of the 2D manifold mesh that isn't already
resident.  The problem with this is that you've got to strictly
segregate things so that iteration over (say) faces gets you what you
wanted.  Yes, I know, sets will do this, but it seems cumbersome...
I can't say I'm crazy about either of these alternatives, nor am I
invested in either one.  Hopefully, someone can come up with something
better.  For what's it's worth, I think this problem is reasonably
(completely?) independent of whether in "normal" single mesh contexts we
require exactly one part and iMesh instance per process.
Having said that, I'll almost certainly be missing tomorrow's telecon.
I will, of course, be happy to kibitz afterwards by email. :-)
Carl
Dr. Carl Ollivier-Gooch, P.Eng.                   Voice: +1-604-822-1854
Associate Professor                                 Fax: +1-604-822-2403
Department of Mechanical Engineering             email: cfog at mech.ubc.ca
University of British Columbia              http://www.mech.ubc.ca/~cfog
Vancouver, BC  V6T 1Z4                  http://tetra.mech.ubc.ca/ANSLab/
More information about the itaps-parallel mailing list
