itaps-parallel Notes from today's meeting
Devine, Karen D kddevin at sandia.gov
Mon Apr 12 13:46:15 CDT 2010
Notes from 4/12/10 phone conference attended by
  RPI:  Mark S., S. Yung (spelling?), Ting
  Uwisc:  Tim T, Jason
  UBC:  Carl
  SNL:  Vitus, Karen
  LLNL:  Mark M.
  Simmetrix:  Mark B., Saurabh Tendulkar
Agreed:  We will meet again on 4/19 at 8:30am PST.
Action Items:
1.  Before our next meeting, write your view of the first big question below
and email it to the list.  Include pros, cons, how apps will use it, how it
will affect implementations, etc.  Mail it to
itaps-parallel at lists.mcs.anl.gov.
2.  Read other peoples' write-ups.  Definitely reply for clarification of
details, but let's save the discussion for the phone call where it is easier
to follow.
My notes from the meeting:
Agreed:  From the iMeshP perspective, an application will typically have,
for a given mesh, one iMesh_instance per process, containing all entities
stored on that process.  The iMesh_instance may have a partition associated
with it, with zero, one or multiple parts per process.  The underlying
implementation may implement this design in any way desired.
If I understand correctly, Simmetrix intends to implement multiple parts per
process by having, internally, multiple "meshes," each representing a part.
The iMesh functions would return results from the union of these meshes; the
iMeshP part-specific functions would return results from individual meshes.
(Does that sound correct, Mark B. and Saurabh?)
The first big question:  Can an entity exist in an iMesh_instance that has a
partition without being owned by any part?
Discussion:  There are several points in iMeshP operations where an entity
may not (yet) have a part assignment.  For example, entities are created
with iMesh_createEnt; they can then be added to a part with
iMesh_addEntToSet (overloaded with a part handle).  But in-between the two
function calls, the entity exists without being in a part.  Some think this
state is acceptable, with the understanding that parallel operations are not
possible on entities that are not in parts.  But this state causes problems
for some implementations, which assume an entity is always in some part
(with a default part assignment set during entity creation).  If we require
that an entity always be assigned to some part, we'll likely need additional
interface functions, such as iMeshP_createEnt that creates an entity and
assigns it to a part.  Even if we don't have the requirement, we could
consider adding such functions as a convenience.
The second big question:  How should we enable multiple partitions of a
single mesh in iMeshP?
The third question:  Should iMeshP_destroyPart should return an error if the
part to be destroyed is not empty?
The answer to this question depends, to some extent, on our answer to the
first big question above.
Cons:  Requires users to explicitly remove entities from parts before
       deleting the parts.  This operation requires three function
       calls:  iMeshP_getEntities, iMesh_rmvEntFromSet (overloaded with
       part handle), iMeshP_destroyPart.
Pros:  Prevents users from shooting themselves in the foot.
       Users would possibly call iMeshP_getEntities and
       iMesh_rmvEntFromSet anyway to do migration to new part.
More information about the itaps-parallel mailing list
